Menu Maintenance
I have customized part tracker, but it doesn’t show up for everyone because they may have bookmarked any of thee several places where part tracker is within the menu tree.
Is there a shortcut solution besides changing every part tracker menu, or having everyone point to a particular menu item location?
Process Calling Maintenance can force everyone to open the same MenuID
Use with care the security of the menu you point to in Process Calling Maintenance needs to be available to all users which use it.
Thanks I’ll try that. I temporarily solved using an updateable BAQ on the Ice.Menu.
