Customization of Method Tracker (8.03.409C)
Thanks for all of your help with this. The doc you uploaded was very helpful
and I was able to get it up and running.
Dustin Biniek
Sent: Mon, December 20, 2010 2:10:03 PM
Subject: [Vantage] Re: Customization of Method Tracker (8.03.409C)
Â
BTW... what screen are you call the method tracker from?
Also, I uploaded a doc - "Adding Non-Menu item Customizations".
Maybe it will help.
If I customize the "method tracker" screen, how do IÂ apply the customization so
that it is launched instead of the standard form? It is not a stand alone
program on the menu so I'm not sure that I can acheive this through menu
maintenance.
Dustin Biniek
Unless I am missing something, "Method Tracker" is not a menu item, so I am
unable to locate it in the tree view so that I can attach the customization.Â
Sent: Mon, December 20, 2010 12:48:32 PM
Â
If you look in security maintenance, menu maintenance, at the tracker menu item,
look toward the bottom of the config screen, you should see a customization
selection drop-down and it should list your customization. This has to be set
for each occurrence of the tracker on the menu tree.
> maintenance.
> Thanks,
> Dustin Biniek
Ha... we had trouble finding it, too.
Right click on a Rev in Part Tracker and Open with...
Of cooner_55421
Sent: Monday, December 20, 2010 3:10 PM
Maybe it will help.
