I'm not certain what you are referring to in this context by SDK but
thanks to those who have replied to this post, I have determined my
errors and all is hunky-dory.
Thanks to everyone for your help!!!!
--Mike
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
--Mike
wrote:
>report
> Mike,
> Yes if you do not have the SDK it just does not work.
> But how well do you know crystal.
> You can create a Subreport that you can then link back to the main
> based on your key fields. I am on 8.03.305 so I do not know if theReport
> Definition is the same as your version but in my version there is aTable
> called CutList (not a true Vantage Table a Temporary Table made byEpicor in
> there XML Output. In CutList Table there is JobNum and AssemblySeqso create
> a Subreport, include the JobAsmbl Table and any other Tables youmay want,
> then link to it with these two fields (and company always linkcompany).
> Then in the Subreport add the fields you want to present.and make a
> But this will be an ODBC connection so you need to have Vantage,
> registry entry to the local PCs, to include the username andpassword for
> the ODBC connection, besides having the ODBC driver install at thelocal
> PCs. So when you run the CutList report it will output to an XMLfile, start
> to create the main report and then run the Subreport in ODBC mode toback and I
> retrieve and present the data. If you need help with this reply
> can send you instructions on that.BOLDLY present
> Hope this helps. I use this technique on my Picking Ticket to
> if that Order is on Credit Hold. Since I could not tie the CustomerTable in
> the Report Definition. I was able to get to it using a ODBCSubreport.
>Behalf Of
> Scott Litzau, MCP
> Olympus Flag & Banner
> Information Systems Manager
> scott.litzau@...
> P: 414-365-9732
> F: 414-355-1931
> -----Original Message-----
> S. Michael Reevesour
> Sent: Thursday, June 05, 2008 12:21 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Cut List Report
> Hello! Let me ask my questions and then you can refer to the
> background below...
> SOFTWARE SPECS:
> First of all, we are running Vantage 8.03.404B on a progress
> database. We have not currently gone live and are going through
> implementation process. Legacy program was not an Epicor product.We
> QUESTIONS:
> Now my questions are directed exclusively to the CutList report.
> have attempted to attach tables to it and then link throughtried
> CrystalReports XI Release 2 without any luck. No errors are thrown
> up, the report simply does not function and messing around with the
> linking you can get the report to function, but nothing will appear
> on the tables that we are trying to add. Specifically we have
> the JobMtl table and then the JobAssmble, (sp?), table.and
> ....Basically, has anyone ever tried to modify the CutList report
> if so, what steps did you take? What problems did you encounter?report
> BACKGROUND:
> We are trying to modify the cutlist report by placing the assembly
> part number and description on there so that we can see what part
> number we are going to be making without looking through the Job
> Traveler. We went ahead and placed the JobAssmble table into a
> definitions table for a code entitled "CutList2"... We had amust have
> consultant look at everything we did and it yet we are having
> difficulty with adding the partnum and description fields. Whenever
> we try to add fields from the JobAssemble table to the report, the
> report goes blank. We have tried messing around with the links
> between the JobAssemble table and the cutlist table with no luck.
> Thanks a ton for any help provided!
> --Mike
> already linked your email address to a yahoo id to enable access. )Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
