Dashboard BAQ Refreshing
As anyone who has built a dashboard knows, sometimes you realize you’ve made a mistake in the BAQ and go back and fix whatever mistake has been made. Is there a way to quickly refresh the BAQ associated with the published dashboard or do I have to go and add a New Query to the current dashboard, delete the old query and start from fresh to push the changes through?
Normally you can just do a properties and click the box to include the new fields. I think deleted fields drop off automagically.
Mark W.
You shouldn’t have to add & delete. You might just have to deploy again. I agree with Mark on the new fields. If your changes are something other than a new field and your changes aren’t pushing through, try clearing your client cache (In Epicor under Settings>Clear Client Cache.) If that STILL doesn’t work, try deleting everything in your local C:\ProgramData\Epicor (folder will not be visible, you must type this address to find it)
I’ve tried clearing the client cache and deleting the local folder and it still doesn’t refresh the dashboard. Any other ideas? (FYI I added a couple new fields, changed some of the relationships between the tables, and added some sorting).
