Dashboard Tracker Error
After migrating from 9.05.702A to 10.1, several of our dashboard trackers used in advanced searches no longer function. I get an error message:
The type or namespace name ‘V_OFB_OrdJobNameSearch_1ViewGridPanel1’ could not be found (are you missing a using directive or an assembly reference?)
This occurs when I test the smart client or deploy the smart client application.
I have noticed that when I un-select ‘Embedded Grid View’ in the tracker properties, the error will go away. But I do need those embedded grid views.
Any suggestions?
Most of your dashboards and BAQ’s are going to have to re-vamped / re-checked.
I tested the BAQ and it works. I also re-created the dashboard and the BAQ from the ground up again. Same results.
