How do they get around the Progress CRC error???? Any Progress code
that accesses the changed field should have to be recompiled. Unless
the conversion from Memo to Character doesn't change the CRC, due to
some strange relation with the two types.
Could you please post the instructions.
Lonnie
Lonnie
--- In vantage@yahoogroups.com, "Brandon Murch" <bmurch@w...> wrote:
> I just got of the phone with support and they emailed instructions
on
> how to change the VB form fields.
> I appreciate everyone's quick responses and help to this dilemma.
> Thank you again !!!
> Brandon R Murch
> Supervisor of Information Technology
> WindStone Medical Packaging
> 406.259.6387
> bmurch@w... <mailto:bmurch@w...>
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Thursday, July 28, 2005 12:09 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Data Administratotion tool
> I've gotten Instructions from Epicor Support for changing the field
> size in the database. Brandon should contact support to get these
> instructions. I've done it several times, especially with VB form
> Character fields. You need to change the # of characters to less
> than 254 for Access or Crystal to treat it as a character field
> instead of a Memo field.
> It is pretty easy to do with the instructions. The only caveat is
> that you have to do it when everyone is out of the system. I am
> actually coming in this weekend to change another field size.
> Good Luck,
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, "lonniedrew" <lonniedrew@c...>
wrote:
> > Do not change any field in any standard Vantage table! You will
> > probably get a CRC error, requiring a re-compile of source code,
> and
> > guess what, most of us don't have Vantage source code!
> > FYI, I have successfully added new tables to the Vantage DB in
the
> > past, but would not recommend it.
> > Lonnie
wrote:
> > > Unfortunately I cannot get around the error message that
Crystal
> > brings
> > > up regarding using memo or blob fields in a formula...I will
try
> and
> > > search for messages regarding what to do...just takes soooo
long
> to
> > > search...
> > > Brandon R Murch
> > > 406.259.6387
> > > From: jeremyrleonard@a... [mailto:jeremyrleonard@a...]
> > > Sent: Thursday, July 28, 2005 11:38 AM
> > > Subject: Re: [Vantage] Data Administratotion tool
> > > I think you want to use a convert or truncate type function in
> > Crystal.
> > > I
> > > know there have been several other postings explaining it in
> > detail.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> > must
> > > have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/links
> > > _____
> > > YAHOO! GROUPS LINKS
> > > * Visit your group "vantage
> > > <http://groups.yahoo.com/group/vantage> " on the web.
> > > * To unsubscribe from this group, send an email to:
> > > vantage-unsubscribe@yahoogroups.com
> > > <mailto:vantage-unsubscribe@yahoogroups.com?
subject=Unsubscribe>
> > > * Your use of Yahoo! Groups is subject to the Yahoo!
> Terms
> > of
> > > Service <http://docs.yahoo.com/info/terms/> .
> > > _____
must
access. )
Builder
> _____
> YAHOO! GROUPS LINKS
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> _____
