6.1 Enlarging the Rev Level box
Yes, I agree....call support for an opinion. Especially since if there really is a way (other than custom programming) to enlarge a field it would surely require their blessing in order to avoid being refused future support.
Really wild kludge suggestion....use a VB Form or other large text field to contain their own shorter rev. # then use this as a an index point in the text field to parse out the customer's longer value. I am not sure though how this would play out with EWB but it might work for other uses like shipping forms and invoice.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Brian Stenglein
Sent: Wednesday, April 12, 2006 2:03 PM
Subject: [Vantage] Re: 6.1 Enlarging the Rev Level box
Todd,
I know what I am doing is only changing the format of the data for
the ODBC connection, but I thought there might be a way to use the
Data Dictionary to do what she wanted. I had never attempted to do
what she is asking and only offered it as a possibility that she
could ask support about. I just went in and looked around for a
second, and maybe there isn't anything useful there after all. Still
might be worth the call though. If you come up with a fairly
painless way to do it, by all means share it with the rest of us just
in case...
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@...> wrote:
> Brian...does changing the DB schema to a smaller value actually re-
size a memo field? Or does it just change the "view" of the data? I
had thought that the actual DB remained unchanged and this was sort
of like saying let the field pretend to be a substring on the first
254 characters (or whatever CR accepts) when in reality the whole
field was still out there. In this case enlarging the schema view
would not really expand the data set. My experience with other
databases has been if you truely expand a field then somewhere in the
process you end up doing an unload/reload of the data and also have
to define some sort of padding rule for the extra space (pad with
spaces, null, zero, etc...). And down the road any updates involving
Epicor generated schema changes would get really messy.
> -Todd C.
> Sent: Wednesday, April 12, 2006 12:41 PM
> Proceed at your own risk, but I've used the Progress Data
Dictionary
> tool to make fields smaller for use in Access or Crystal, so I
don't
> see why you couldn't do it to make a field bigger. Call support
and
> see if they can give you some instructions and an idea what
problems
> may result from such a change. You do need to have everyone out of
the
> DB prior to making the change and of course you'd want to try it on
a
> test DB first.
> Good luck,
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, "kathyschaich" <kathy.schaich@>
> wrote:
> > We are currently on version 6.1 and with the capability of
> > personalizing a screen, I am able to lengthen the box in Part
Master
> > for the Revision level, but is there a way to make the field
larger
> as
> > to add more digits? We have several customers who have extremely
long
> > revision levels and need more room in this field. Any help you
can
> > give me would be appreciated.
> > Thanks
> > Kathy Schaich
> > Ultra Tool & Manufacturing, Inc.
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage
< http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/> .
> _____
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
personalizing a screen, I am able to lengthen the box in Part Master
for the Revision level, but is there a way to make the field larger as
to add more digits? We have several customers who have extremely long
revision levels and need more room in this field. Any help you can
Kathy Schaich
Kathy,
Sorry, no dice. Unless you would like to talk to custom programming.
Good luck,
Aaron Hoyt
Vantage Plastics
Of kathyschaich
Sent: Wednesday, April 12, 2006 8:23 AM
Subject: Re: [Vantage] 6.1 Enlarging the Rev Level box
Kathy Schaich
Yahoo! Groups Links
Proceed at your own risk, but I've used the Progress Data Dictionary
tool to make fields smaller for use in Access or Crystal, so I don't
see why you couldn't do it to make a field bigger. Call support and
see if they can give you some instructions and an idea what problems
may result from such a change. You do need to have everyone out of the
DB prior to making the change and of course you'd want to try it on a
test DB first.
Good luck,
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "kathyschaich" <kathy.schaich@...>
as
> Thanks
> Kathy Schaich
Brian...does changing the DB schema to a smaller value actually re-size a memo field? Or does it just change the "view" of the data? I had thought that the actual DB remained unchanged and this was sort of like saying let the field pretend to be a substring on the first 254 characters (or whatever CR accepts) when in reality the whole field was still out there. In this case enlarging the schema view would not really expand the data set. My experience with other databases has been if you truely expand a field then somewhere in the process you end up doing an unload/reload of the data and also have to define some sort of padding rule for the extra space (pad with spaces, null, zero, etc...). And down the road any updates involving Epicor generated schema changes would get really messy.
-Todd C.
test DB first.
Good luck,
Brian Stenglein
Clow Stamping Co.
as
> Thanks
> Kathy Schaich
_____
YAHOO! GROUPS LINKS
_____
Todd,
in case...
Brian Stenglein
Clow Stamping Co.
> -Todd C.
Dictionary
don't
and
problems
the
a
> test DB first.
> Good luck,
> Brian Stenglein
> Clow Stamping Co.
Master
larger
> as
long
can
> > Thanks
> > Kathy Schaich
access. )
> _____
> YAHOO! GROUPS LINKS
> _____
