Data Directive BPM to update SellingQuantity does not update OrderHed Total Charge
I have got a UD field called JobSQM_c in OrderDtl where our draftsman will update this square meter based on what is drawn in CAD.
So I have created a Data BPM, so that the SellingQuantity and OrderQty will be updated through the BPM. I followed the trace closely and the two calls that are important are
ChangeSellingQtyMaster
and
MasterUpdate
I ran both of them with the exact parameters, the OrderDtl will update correctly, but the OrderHed Total Charge will not update at all. What did I do wrong here?
foreach(var ttOrderDtlRow in (from row in ttOrderDtl where row.Updated() select row))
	decimal sellingQty = ttOrderDtlRow.JobSQM_c;
	this.PublishInfoMessage("Updating SQM in Sales Order Line Qty to: " + sellingQty , Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "OrderDtl", "Update");
	Erp.Contracts.SalesOrderSvcContract salesOrderSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SalesOrderSvcContract>(Db);
	string opWarningMsg;
	bool morePages = false;
	Erp.Tablesets.SalesOrderTableset sods = salesOrderSvc.GetRows("OrderNum="+ ttOrderDtlRow.OrderNum.ToString(),
																																"","","OrderLine=" + ttOrderDtlRow.OrderLine.ToString(),
        "","","","","","","","","","","","",0,1, out morePages);
  string cResponseMsg, cDisplayMsg, cCompliantMsg, cResponseMsgOrdRel;
  bool lContinue = false;
	if(sods.OrderDtl.Count > 0)
     sods.OrderDtl[0].RowMod = "U";
		string pcMessage, pcNegQtyAction,cSellingQtyChangeMsgText;
		salesOrderSvc.ChangeSellingQtyMaster(ref sods, sellingQty, true , true, true, true, true, true, ttOrderDtlRow.PartNum, "","","",ttOrderDtlRow.SalesUM, 1,
						out pcMessage,out   pcNegQtyAction, out opWarningMsg, out cSellingQtyChangeMsgText);
 	 sods.OrderDtl[0].CurrencySwitch = false;
		sods.TaxConnectStatus[0].ETCOffline = true;
		sods.TaxConnectStatus[0].RowMod = "U";
  	salesOrderSvc.MasterUpdate(false, "OrderDtl", sods.OrderHed[0].CustNum, sods.OrderHed[0].OrderNum, false, out lContinue, out cResponseMsg, out cDisplayMsg, out cCompliantMsg, 					out cResponseMsgOrdRel,   ref sods);
so the draftsman opens the order, changes the value, saves the order and closes it?
And you’re making the change to SellingQty in-transaction?
I’m trying to remember how we did something similar - there might be other fields containing “qty” you have to update, and you might have to unfirm the release first - but our forms are so customized I might be completely off track.
Another big help is to ensure you can simulate the ens result in the BL Tester (search this forum for how-tos)
