I've had this problem before and it is usually a link error.
Carefully check all your links.
--- In vantage@yahoogroups.com, "jonesdj55" <djones@...> wrote:
> Hello, I am trying to create a Crystal Report XI report but am
> getting the error "Failed to retrieve data from the database."
When
> I click OK I get the error:
> Database Connector Error: 'HY000:[DataDirect][ODBC OPENEDGE driver]
> [OPENEDGE]Unable to allocate disk block for temp table use [MM -
No
> data block] (7631) [Database Vendor Code: -16001 ]'
> The report involves the POHeader, PODetail, PORel, and Vendor
> tables. I am reporting by Vendor, the PODetail(PONum, PartNum,
> LineDesc, OrderQty, UnitCost) and PORel(ExpChart, DueDate)
> information with a calculated field (OrderQty * UnitCost).
> I have gotten this error before but when I changed a link between
> the various tables (detail to head vs. head to detail) the report
> worked.
> This seems to be a problem with the complexity and size of the
data.
> Do I need to setup a temporary work space?
> Any help would be appreciated.
> Thanks
> djj
