I have been dealing with this issue recently as we are getting ready to
convert from time card labor entry to shop floor data collection. I have a
Symbol scanner - I had to do as Todd suggests and turn on full ASCII mode.
My scanner did not come with this enabled. Since I did that, I have been
able to automate quite a bit of the entries into Vantage. I am getting
ready to tackle the traveler next! Thanks to Todd and Greg Krumrey - you
are my heroes :o)
Diane Rowberry
Westwood Precision
425-742-7011 x43
Sent: Wednesday, February 13, 2002 8:53 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Dataworks Code 39
In my scanner manual (Welch-Allyn ImageTeam 3800) there is a scan bar to
turn on (or off) "full mode". I have not had to use it because it appears
"Full" is on by default. This code would probably be specific to the
brand/model of scanner so check you manual or perhaps tech support for
your
scanner. You might also try another code like the F6 example on any
Vantage
screen and see if the print screen window pops up. This might seperate a
problem with full mode from an issue with the ETX/EOT for the ALT-A.
-Todd C.
Sent: Wednesday, February 13, 2002 10:41 AM
When I send *$CA$D* (printed in Dataworks Code 39)as a Start Activity
command, I get $D entered into the Job Number. Either I've failed to
modify
my scanner's settings, or the Dataworks Code 39 that I'm printing is not
the
same as the Barcode 39 that the scanner is reading.
Any comments?
Join the world's largest e-mail service with MSN Hotmail.
http://www.hotmail.com
have
Yahoo! Groups Sponsor
ADVERTISEMENT
are my heroes :o)
Diane Rowberry
Westwood Precision
425-742-7011 x43
your
Vantage
-Todd C.
modify
the
Any comments?
>From: Todd Caughey <caugheyt@...>mode
>Reply-To: vantage@yahoogroups.com
>To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
>Date: Tue, 12 Feb 2002 14:44:52 -0600
>If your scanner supports "Full Mode" for Code-39 (check the manual, most
>do)
>then ALT-x keys can be accomplished by using the following sequences.
>Full
>mode adds many normally non-Code39 characters by using two character
>combos.
>Each ALT seqeuence is started by the ASCII ETX character which in full
>would be $C, it is ended with the EOT character $D. Anything between(like
>A) would be ALTed as if you held down the Alt key and press A. So thefull
>string would be (with the required * at each end) "*$CA$D*" for Alt-A.have
>Note, I have not tried this particular string but others like "*$M*" for
>Enter work.
>The Full Code39 ASCII equivalents for the others are:
>ESC = %A
>TAB or HT (horizontal tab) = $I ( that's a letter 'eye')
>F2 = ASCII ETB = $W
>F6 = ASCII ESC = %A (as above) but is useful for Print Screen
>CR = $M
>-Todd C.
>From: Steve Ashton [mailto:steve_universal@...]
>Sent: Tuesday, February 12, 2002 2:24 PM
>To: Vantage Users
>Subject: [Vantage] Dataworks Code 39
>Hi Group,
>Does anyone know the Dataworks Code 39 codes that could be scanned to
>manuver through data collection? I'm looking for codes that perform the
>keyboard's functions like Alt-A, Esc, Tab, F2, etc.
>I have a PSC QuickScan 6000+ with a keyboard wedge that I'd like the shop
>employees to use instead of the data collection station's keyboard and
>mouse. We using Version 4.0.904
>Thanks
>Steve Ashton
>Universal Showcase Ltd
>an IDX company
>steve.ashton@...
>905-695-3045
>already linked your email address to a yahoo id to enable access. )_________________________________________________________________
><http://groups.yahoo.com/group/vantage/files/.>
><http://groups.yahoo.com/group/vantage/messages>
><http://groups.yahoo.com/group/vantage/links>
><http://docs.yahoo.com/info/terms/> .
have
ADVERTISEMENT
