Juliet,
Here's one additional option. Instead of purchasing PcAnywhere, you may
want to download the VNC remote viewer from AT&T Laboratories (
http://www.uk.research.att.com/vnc <
http://www.uk.research.att.com/vnc> ).
As Todd said earlier this week regarding a different topic: works great,
less filling.
Regards,
Scott
tanderson@...]
Sent: Wednesday, April 04, 2001 1:01 PM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] Dial-up Access
Juliet,
Fast, down and dirty. Go buy PcAnywhere and install it on your PC at work
and your PC at home. Connect via NETWORK using the IP address of your
desktop PC. You can then dial into your servers via RAS and then link to
your desktop via the network. From that point you will be running Vantage
on your desktop PC at work and "Seeing" the screens at home. You can also
setup PcAnywhere so that your printer at home is an "Option" on your desktop
PC at work. This allows you to print reports at home.
This is the cheapest, easiest, solution for 1 person.
Also - make sure to set your video drivers to the lowest number of colors
you can handle ( 32 ) instead of 16k or 32k or true-color and make sure both
PC's are in 800x680 mode. The larger the screen pixels and the larger the
number of colors the slower PcAnywhere will work.
Good luck,
Todd Anderson
jmartin@...]
Sent: Wednesday, April 04, 2001 11:39 AM
To:
Subject: [Vantage] Dial-up Access
Can anyone give me any tips on accessing Vantage from an external dial -
up location? I am not having much luck. I do have the external machine
dialed into the internal PC. I also can see the network. What do I
need to have in place so the external machine can run vantage from their
PC.
Juliet
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=162801.1342250.2934640.1280005/D=egroupmail/S=1700007
183:N/A=599089/*
http://www.knowledgestorm.com/jump_white.html?c=Yahoo
http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer> &n=eLer
t_ComputersInternet_Software_WhiteGridOptions&t=ad> Click Here to Find
Software Faster
Click Here to Find Software Faster
http://us.adserver.yahoo.com/l?M=162801.1342250.2934640.1280005/D=egroupmai
l/S=1700007183:N/A=599089/rand=816527449>
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/.>
http://groups.yahoo.com/group/vantage/files/.> > Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
http://docs.yahoo.com/info/terms/ <
http://docs.yahoo.com/info/terms/> >
Service.
183:N/A=599088/*
t_ComputersInternet_Software_WhiteGridTime&t=ad> Click Here to Find Software
Faster
l/S=1700007183:N/A=599088/rand=938096643>
http://groups.yahoo.com/group/vantage/files/.> Note: You must have
http://docs.yahoo.com/info/terms/> Terms of Service.
