Once it is invoiced, it is locked to that job.
Regards,
Andrew Best
Kice Industries, Inc.
P(316)744-7151
F(316)295-2412
Of Robert Brown
Sent: Wednesday, February 18, 2009 1:57 PM
Subject: Re: [Vantage] Re: Direct Buy Material Transfer
If it has already been recived direct to job cost, not much you can do.
You can only make manual cost adjustments to the jobs at this point.
If not yet received, change the PO link to the other job.
Rob
--- On Wed, 2/18/09, jpfinch1 <sway@...
<mailto:sway%40micindustries.com> > wrote:
From: jpfinch1 <sway@... <mailto:sway%40micindustries.com>
Date: Wednesday, February 18, 2009, 12:57 PM
I can't do a return to stock for non-part# items. They are not part
numbers in the Part Master Table. Purchased non-part bought directly
to the job.
Regards,
Andrew Best
P(316)744-7151
F(316)295-2412
Of Robert Brown
Rob
>Subject: [Vantage] Re: Direct Buy Material Transfer
to the job.
--- In vantage@yahoogroups .com, "CharlieSmith" <CSmith@...> wrote:
> Do a return to stock and then issue the stock to the new job.
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of jpfinch1
> Sent: Wednesday, February 18, 2009 11:00 AM
> To: vantage@yahoogroups .com
> Subject: [Vantage] Direct Buy Material Transfer
> Does anyone know a way, other than job adjustment, to transfer
> material cost from a "Purchase Direct" line between jobs. We have
> purchased non-part numbered material directly to a job but would
now
> like to use that material on a different job. The material has
already
> been received and invoiced. Any suggestions?
