Ivan A. Wright | Systems Interface Development SpecialistÂ
NRS -- 100% Employee OwnedÂ
Â
2009 S. Main St. Moscow, ID 83843
p: 208.883.7834 ext.262 | f: 208.882.1744
Not sure if you ever got an answer but I had to do this today so I though I would post one.
A good write up of the toolbars is here:
epicor-development.blogspot.com/2014/04/epicor-9-toolbars.html
Open your dashboard in customization mode and add
using Infragistics.Win.UltraWinToolbars;
and a Form_Load Event with
baseToolbarsManager.Tools["RefreshTool"].SharedProps.Visible=false;
Hope that helps,
John
If I want to move the DELETE button away from the SAVE button. Can I use the example codes to set false to the DeleteTool and then create a buttonTool for deleteTool. This way the X will be at the very end?
They were adding a PrintTool button and it was added to the end in the example they give.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Monday, September 28, 2015 8:03 AM
Subject: [Vantage] Re: Disable Refresh Button
Ivan,
Hope that helps,
John
Miguel A. Santillan
Sent: Monday, September 28, 2015 9:21 AM
Subject: RE: [Vantage] Re: Disable Refresh Button
You can set that in 'Global Options', I believe.
--Matt Caldwell
