Mark
You can but it gets a bit messy when you have one material issue item
which disassembles into many parts back into stock
Gary
Of Mark Wonsil
Sent: 23 January 2007 15:36
Subject: RE: [Vantage] Re: Disassemble finished goods
Hi Scott and Gary,
We can certainly use the Misc. Return to Stock, the issue is the number
of
parts makes it a bigger task. The ultimate solution would work with the
RMA
system. We already have a "Return Assembly to Stock" but it would be
"real
cool" to have a "Return Components to Stock". The command would list the
components from the Job or Engineering records and the user would
selectively
return some parts to stock and scrap others (parts that can't be reused:
seals, gaskets, etc.)
Mark W.
Gary
Of Mark Wonsil
Hi Scott and Gary,
> You can also use Material Salvage.Could you elaborate on how to use each of these methods?
> Scott
> You can now do this in Vantage 8.00 using 'Job Parts'
> functionality. I think you need an Advanced Production License though
> > Gary Parfrey
of
RMA
"real
selectively
Mark W.
