Discrepancy between General Ledger & Subsidiary Led ger
Randy's suggestion of posting the invoice to the period matching the
date you actually enter it will be fine if you have the G/L interface
for purchase order receipts turned on in Vantage. Otherwise you would
not be following proper accounting procedures. Consider a hypothetical
invoice for an inventory item received in December, whose invoice is
not posted to the G/L until January. The year end physical inventory
might include the materials but your G/L would not. An inventory
adjustment would be posted in December only to have the January
posting of the invoice duplicate the adjustment. Of course this could
be avoided by a manual accrual being posted into December's G/L and a
reversing entry posted in January if you recognized that the invoice
had not been posted yet. This would all be more work than it is worth
in my opinion. I would recomment posting invoices to the G/L in the
period it was actually received and make sure that A/P batch edit
lists are reviewed prior to posting for incorrect dates.
Wouln't another possible fix be to enter a credit memo for the same
amount, to the same G/L account, using the same "bad" date, and then
re-enter the invoice with the correct date? Just select all 3 items
with your next check run to remove them all from the aging reports.
Jeff Milbrath, CPA
Controller
Hartford Finishing, Inc.
--- In vantage@yahoogroups.com, Randy Lunsford <rlunsf@e...> wrote:
> Dennis, There are two things that I found that have made
reconciliation a
> breeze. I haven't been off in over a year, and that was due to an entry
> error. The first step is the A/P entry of the invoice. If it is
linked to
> a PO, make sure that you enter the G/L period of the month of the
actual A/P
> entry, not the receipt date. In other words, if you have a PO that was
> received in December and you don't make the A/P entry until January, you
> enter the G/L period of January for the entry. Also, when you print
the A/P
> aging report, you need to select the "Fiscal Period" option instead
of the
> "Invoice Date" option. This will only pull in the invoices entered
in the
> G/L month you are trying to reconcile.
> Randall Lunsford
> Excel Machinery, Ltd.
> e-mail: rlunsf@e...
> Phone: (806) 335-4565 ext. 531
> Fax: (806) 335-9017
> -----Original Message-----
> From: Dennis O'Hara [mailto:d.ohara@s...]
> Sent: Sunday, January 09, 2005 10:51 PM
> To: Vantage User Group (Vantage User Group)
> Subject: [Vantage] Discrepancy between General Ledger & Subsidiary
Ledger
> We have identified a discrepancy between the General ledger and the
Accounts
> payable ledger report - I have been able to identify some
transactions that
> have not been processed correctly but the sheer volume of entries
make it a
> mind numbing exercise to investigate manually. Has anybody been able to
> develop a report that compares general ledger entry postings to
subsidiary
> ledger postings or alternatively is there a prove balance mechanism
> Regards
> Dennis O'Hara
> General Manager Finance
> The Signcraft Group
> Tel 61 3 9687 8455 Fax 61 3 9687 7235
> Direct 61 3 8371 3711
> d.ohara@s...
> www.signcraft.com.au <www.signcraft.com.au>
> The Signcraft Group Email Disclaimer.
> Confidentiality and Limited Liability Statement.
> This message contains privileged and confidential information
> intended only for the use of the addressee above. If you are
> not the intended recipient of the message, you must not
> disseminate, copy or take any action in relation to it.
> If you have received this message in error, please notify
> The Signcraft Group immediately. Any views expressed in this
> message are those of the individual sender, except where the
> sender specifically states them to be the view of The Signcraft Group.
must have
Builder and
> Yahoo! Groups Links
Dennis, There are two things that I found that have made reconciliation a
error. The first step is the A/P entry of the invoice. If it is linked to
a PO, make sure that you enter the G/L period of the month of the actual A/P
enter the G/L period of January for the entry. Also, when you print the A/P
aging report, you need to select the "Fiscal Period" option instead of the
"Invoice Date" option. This will only pull in the invoices entered in the
Randall Lunsford
e-mail: rlunsf@...
Fax: (806) 335-9017
Subject: [Vantage] Discrepancy between General Ledger & Subsidiary Ledger
We have identified a discrepancy between the General ledger and the Accounts
payable ledger report - I have been able to identify some transactions that
have not been processed correctly but the sheer volume of entries make it a
develop a report that compares general ledger entry postings to subsidiary
Regards
Dennis O'Hara
The Signcraft Group
d.ohara@...
Yahoo! Groups Links
Also, don't forget the dreaded possibility of an incorrectly entered
invoice date (i.e. 12/31/04 entered as 12/31/40). Assuming the invoice
was posted to the correct month/period, in this case "12", the invoice's
amount will be included in the G/L's balance, but will not show up in
the Sub Ledger's balance, since you are running it as of 12/31/04. The
way to find if this occurred is to print off a G/L detail for your A/P
account and look at the first/last couple of entries to see if an
invoice date was incorrectly entered.
Thanks!
Rick Ludwig
Sent: Monday, January 10, 2005 8:40 AM
Subject: RE: [Vantage] Discrepancy between General Ledger & Subsidiary
Ledger
a
to
A/P
A/P
the
the
Randall Lunsford
e-mail: rlunsf@...
Fax: (806) 335-9017
Ledger
Accounts
that
it a
subsidiary
Regards
Dennis O'Hara
The Signcraft Group
d.ohara@...
have
and
Yahoo! Groups Links
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
