Display a message (just once)
Hi everyone,
I have a custom tickbox on the Project Entry screen and I am trying to get a message to display when a Quote is opened or created that is linked to this project if the tickbox is true.
I first tried a customization on the QuoteHed, using a BAQ DataView, which worked to a degree, but the message showed four times in succession. I then tried a BPM both pre and post method directive. Having run a trace I thought the method would be GetByID, this again worked partially but the message pops up after any change is made on the Quote.
Can anyone advise me on the best way to accomplish what I am trying to do?
Thanks in advance.
In customization, just create a boolean like MessageDisplayedAlready = false. Then when you display the message set it to true. Make sure than when a new quote is opened or created to set the value to false again.
Thanks Marjorie, that’s a good idea. I will give it try when I’m back working on Monday and let you know how it goes.
Thanks for your help.
