Stephen, thank you. This solution worked great, just as you mentioned
below. Again, Thank You!
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
>disconnect
> To clarify the SQL width I mentioned.
> Open Data Administration and connect to your database (test or pilot
> first)
> (Note you will need to be in single user mode to modify (i.e.
> users V6))characters in
> Then choose Tools->Data Dictionary
> For example select the Table DMRCorAct
> Choose SQL options-> adjust field width (progress 9.1D )
> The SQL width is what is used when accessing the database via ODBC /
> JDBC. The problems that can occur are that there are more
> the field than specified in the width.[PROGRESS]
> "ODBC error:[DataDirect-Technologies][ODBC PROGRESS driver]
> Column CauseInv in table PUB.DMRCorAct has value exceeding its maxwidth is
> length or precision"
> The error detailed is that of an ODBC error indicating that SQL
> the issue here.and you
> Note the Width of the CauseInv is set to 16, update this to 2000
> should not get this ODBC error.result
> Jill points out particular limitations of Crystal 8.5 this would
> in a different error / truncated data.huge
> Hope this helps
> Stephen Edginton
> From: Jill Pleau [mailto:jpleau@...]
> Sent: 25 September 2006 21:56
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: DMRCorAct Table
> I'd be interested in the resolution to this problem. It's been my
> understanding that Crystal 8.5 has limitations in regards to the
> comment fields that are in the newer versions of Vantage -- the fixupgrade to
> answer that I've gotten from the crystal groups are simply --
> Crystal 10. So I run problem reports in 10.SQL
> I didn't understand the comment from Stephen about increasing the
> width for these fields; this is done with data administration tool??
> Thanks, Jill
