You say your DB is 23GB in size, but where is all that space located?
I generally find that a DB that size, the majority of the space is usually
taken up by the Change Logs.
For example, I am currently working on a database that is 17GB in size,
however their change logs alone take up 11GB of that space.
Purging change logs from old data is an excellent way to clear up DB space
and reduce it in overall size. Many people don't even realize the volume of
data that they have in the change logs.
michael.hutcheson@...
Sent: Tuesday, April 05, 2011 11:16 AM
Subject: [Vantage] Re: Do I need a new server
Ok, I reduced the APW to 2 and the lock table entries to 8192 (which was the
default). With regards to the # of blocks in DB buffer - we are using
standard 4 blocks, so the current setting of 160000 translates to 655mb. I
tried to increase this to 480000 which translates to 1.9GB but the the app
server would not start. (The server has 8GB and is the Enterprise edition of
Server 03 so all 8GB is recognized). The following was recorded in the logs:
-- Unable to attach shared memory
Global\sharemem.e.epicor.mfgsys803.db.mfgsys.0, error 0. (1720)
I spoke with Epicor who said a bug is present in OpenEdge 10.1B that will
not allow the value to go above a certain point - however they did not know
what point. Using trial and error, it appears the value cannot go above
180000 which translates to 747 mb. We are using the latest SP3 and hotfix 33
for OpenEdge and Epicor do not have an answer.
Where do I go from here? Our database is 23GB in size and only 655mb is in
RAM.
Regards,
Michael
RAM.
Regards,
Michael
--- In vantage@yahoogroups.com, Zac Jason Woodward <zac@...> wrote:
> In addition you have to be on 9.05 or higher to be able to get true multi
core CPU support.
> "Zac" Jason Woodward
> Network Administrator
> Intermountain Electronics, Inc.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> Creating customer confidence through extraordinary service and experienced
industry experts.
> Behalf Of Hatcher, John
> Sent: Tuesday, April 05, 2011 5:42 AM
> It's not just windows but OpenEdge that is limiting memory use. It is
> my understanding that you need to be on 10.2 or higher and a version
> of windows that supports 64bit to make use of anything beyond 4Gb.
> John A. Hatcher
> Manager of IS
> Versa Products Co., Inc.
> (201) 843-2400 x4148
> (201) 843-2931 fax
