[ok] Server Performance
Forgot to put that. DB size = 2.4 GB.
I Knew not to use Raid 5, raid 10 probably would have been a better
choice.
Of Paul V. Blais
Sent: Thursday, February 01, 2007 1:59 PM
Subject: RE: [ok] [Vantage] Server Performance
Why Raid 1? All depends on your database size.
Behalf
Of Moore, Jim (Anniston)
Sent: Thursday, February 01, 2007 2:54 PM
New to Vantage 6.1. Going live in 2 weeks from 4.0.
What are the optimal DB configuration property settings for Vantage 6.1
for a server with 4 GB memory / 29 users / 10 DC users / Raid 1
Network is 1 GB and 100 MB . / Desktops are 95% Windows XP Pro.
What are the best settings for:
# Blocks in DB Buffer:
# Hash table entries:
# Lock table entries:
Maximum users:
Maximum servers:
Any other settings I need to adjust?
Jim Moore
Behalf
Of Dan Ernst
Sent: Thursday, February 01, 2007 1:00 PM
Subject: Re: [ok] [Vantage] Server Performance
We are using Raid 10 configuration
If you are referring to #blocks in db buffer, 6.1 is set at 40000 and
8.03 is set at 0
Not sure about the hyperthreading but I would guess that it is not
enabled
Dan Ernst
Correct Craft, Inc.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"Charles Paluska - HPN"
<cpaluska@...> wrote:
> The first two things that come to mind are:
> 1. How much memory are you allocating to each - look at
the "block" values in the Progress Explorer for each db?
> 2. What type of Raid configuration are you using?
> A third item to look into is if HyperThreading in enabled or not on
your processors.
> Charles Paluska
> Palus Technologies, LLC
> www.homeplanetnetworks.com
> From: Dan Ernst
> Sent: Thursday, February 01, 2007 12:32 PM
> Subject: [ok] [Vantage] Server Performance
> Is anyone else running Vantage 6.1 and Vantage 8.03 on the same
server?
> I am using a Dell 2800 with dual 3.4ghz and 4gb ram and the
performance
> is terrible ever since we installed 8.03. I have already changed
the
> port number for OpenEdge 10.0B to 20555, it was using the same as
> Progress 91D. The only thing on this server is Vantage, any
suggestions?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
1. How much memory are you allocating to each - look at the "block" values in the Progress Explorer for each db?
A third item to look into is if HyperThreading in enabled or not on your processors.
Charles Paluska
Is anyone else running Vantage 6.1 and Vantage 8.03 on the same server?
I am using a Dell 2800 with dual 3.4ghz and 4gb ram and the performance
is terrible ever since we installed 8.03. I have already changed the
Progress 91D. The only thing on this server is Vantage, any suggestions?
Dan Ernst
Correct Craft, Inc.
8.03 is set at 0
enabled
Dan Ernst
Correct Craft, Inc.
--- In vantage@yahoogroups.com, "Charles Paluska - HPN"
your processors.
> Charles Paluska
> From: Dan Ernst
server?
performance
the
suggestions?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
Dan,
You will want to put in a block value for the 8.03 database. Here's
what Epicor recommends as a "starting point"
10000 blocks equals 41.5 mb (4k block size) or 83.8 mb (8k block
size).
Epicor recommends that you pre-load 1.5x the size of your database
(the .d1 file). For example if you had 100MB database then you would
want to pre-load (or allocate) 150mb worth into memory. Using the
formula above, 40000 blocks ~ 166MB (4k size) or 20000 blocks ~ 167mb
(8k size).
This is not exact, but should help you size the server accordingly.
Also, make sure your anti-virus real-time scanning does not include
the epicor, client803, documents and settings, etc. directories as
this will cause a major impact as well.
Hope this helps,
Jason Claggett
Sr. Systems Engineer
2W Technologies, LLC
Epicor Channel Partner
www.2wtech.com
and
> 8.03 is set at 0
> enabled
> Thanks
> Dan Ernst
> Correct Craft, Inc.
on
> your processors.
> > Charles Paluska
> > From: Dan Ernst
> server?
> performance
changed
> the
as
> suggestions?
> > Thanks
> > Dan Ernst
> > Correct Craft, Inc.
Maximum users:
Maximum servers:
Jim Moore
Of Dan Ernst
8.03 is set at 0
enabled
Dan Ernst
Correct Craft, Inc.
your processors.
> Charles Paluska
> From: Dan Ernst
server?
performance
the
suggestions?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
Maximum users:
Maximum servers:
Jim Moore
Behalf
Of Dan Ernst
8.03 is set at 0
enabled
Dan Ernst
Correct Craft, Inc.
your processors.
> Charles Paluska
> From: Dan Ernst
server?
performance
the
suggestions?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
We have a 14gb database for 6.1 and 8.03
I will check the realtime scan on the antivirus. We did bring on 2
new servers and one of them did get our antivirus software installed
and maybe it has been set to scan the Epicor folders
Dan Ernst
Correct Craft, Inc.
--- In vantage@yahoogroups.com, "jason_claggett" <jason@...> wrote:
> Dan,
> size).
would
167mb
> (8k size).
> Hope this helps,
> Jason Claggett
> www.2wtech.com
> and
> > 8.03 is set at 0
not
> > enabled
> > Thanks
> > Dan Ernst
> > Correct Craft, Inc.
not
> on
> > your processors.
> > > Charles Paluska
> > > From: Dan Ernst
same
> > server?
> > performance
> changed
> > the
same
> as
> > suggestions?
> > > Thanks
> > > Dan Ernst
> > > Correct Craft, Inc.
