Document Management
We would like to know the experiences anyone is having with Doc.
Management. Is it good ,bad, not worth it etc. Also we inquiring about the
doc. management pro. Any input on this will be appreciated
We have been using AutoVue to browse related documents. All of our
production prints are scanned and saved as a .tif image. Everyone then has
access to view or print any print from their PC. Saves the hassle of going
to the filing cabinet and finding out it's not in file. It works quite
well.
John Rodewald
Sr. CAD Engineer
National Tube Form, LLC
Phone: (219) 478-2363 ext. 205
Fax: (219) 478-1043
John.Rodewald@...
Sent: Wednesday, September 27, 2000 8:10 AM
To: 'vantage@egroups.com'
Subject: [Vantage] Document Management
about the
-------------------------- eGroups Sponsor
We no longer allow attachments to files. To access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try
it, go to www.egroups.com, login and be sure to save your password, choose
My Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
We make extensive use of document management. We've standardized our
software to microsoft products, though we have used it with a smattering of
other software. We use it to control our process cards for manufacturing.
A process card is printed at the start of the job then destroyed at the end
of the job. Only our process engineers can make changes to these cards. (NT
security and document passwords). This method was described as impressive
by our QS9000 auditors. (We passed certification) I would like to see more
features but overall I would call it very very useful to us.
Shirley H. Graver
Systems Administrator
Rubber Associates Inc. (Certified to QS9000/ISO9002)
Cleveland/Akron, Ohio
Watch for 2 key elements:
1) When you create a new revision letter for an item you will have to
manually reconnect all related documents to the new revision. The
assumption is that all documents are revision sensitive and should not be
automatically linked to the the new upper level revision. Personally, I'd
like a button that says "Copy Docs" so that if you want to copy them you can
without having to re-drill out to each document. The old copy and paste
concept ...
2) There is also a rather old suggestion floating around EPICOR to give us
the option to print some/all related documents when we print travelers.
Specifically an option on the document management screen to specify which
documents should be printed with the travelers and/or which documents should
be printed with packing slips, etc. and then an option on the traveler print
screen to click if you want the related documents that have also been
checked.
Other then these 2 issues it isn't bad. Be very careful how you setup your
document directories. For this to work you have to have a network drive
letter that is common to all pc's - like 'W'. Then you have to have some
logical way of setting up your directories - like
W:\CST\CUST-NAME\ITEM-NO\DOC-NAME.DOC. Lastly you will need to think
through your security since different groups of people will need to update
different types of documents while most people will need read-only access.
Also, understand that once you setup this directory structure you will be
stuck with it basically forever since to change it would require relinking
all of your documents.
Another thought for you is that you could:
* Setup your "W" drive or whatever you would like to use
* Setup your directories and start saving documents
* Purchase AutoVue on the open market - not from EPICOR
* Users would then use explorer to browse your "W" drive to find the
documents they are looking for and then print them.
The value to AutoVue ( or any similar package ) is that most of the company
will have READ-ONLY access to these master documents while some departments
can be given FULL-ACCESS to add/update. ( At a previous company we had ALL
.DWG AutoCAD files on a network drive with read-only access to EVERYONE in
the company except 1 person - the final checker in the engineering
department. When an engineer wanted to change a drawing they would copy it
down to their personal directory, make the changes, and then copy it into a
"Checker" directory. The final checker would double check that all
standards had been met and then would copy / overlay it back top the master
drive. )
You might want to purchase AutoVue, setup your directories, give it a try,
and then if you are still interested in the concept purchase the Doc-Mg
module.
Good luck
Todd Anderson
J. Rubin & Co.
eGroups Sponsor
<http://click.egroups.com/1/9500/13/_/411782/_/970060429/>
<http://adimg.egroups.com/img/9500/13/_/411782/_/970060429/468x60_hate_searc
hing5.gif>
<http://www.egroups.com/files/vantage/>
Not worth it. It's very cumbersome and nothing is automated.
If you just want to view autocad drawings get autodesk's free
viewer. If you have other formats then get Autovue.
Is anybody willing to share their experience of working with Document
Management Module?
If you are kind to spend a few minutes for a phone conversation, please
e-mail me your phone number or give me a call at your convenience.
Thank you.
Vladimir Tigay
Vice President of
Strategic Planning
WLS Stamping Company
vtigay@...
216/271-5100 x3020
We use Document Management extensively, Feel free to call and chat about
it. 330-745-2186 EX 102
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
Sent: Thursday, February 15, 2001 1:53 PM
Management Module?
Thank you.
Vladimir Tigay
Vice President of
Strategic Planning
vtigay@...
216/271-5100 x3020
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=176325.1312152.2904070.1252795/D=egroupmail/S=1700007
183:N/A=567139/R=1/*http://domains.yahoo.com>
183:N/A=567139/R=2/*http://domains.yahoo.com>
www.
<http://us.adserver.yahoo.com/l?M=176325.1312152.2904070.1252795/D=egroupmai
l/S=1700007183:N/A=567139/rand=168596376>
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
I am looking to set up the ablity to attach Autocad Drawings to
parts. Can anyone recommend a good viewer to use
Rhonda
We use Volo Viewer. We obtained it free from Autodesk. It will allow us to
open DWG and DXF files.
Paul L.
ASPI
Sent: Tuesday, April 29, 2003 9:21 AM
Rhonda
We use Voloview Express.
Rhonda
We have our engineers turn the ACAD files into PDF files. Check out
PDF995.com. I got a 25 user license for $200. You can get it for free - It
fully works you just get two pop-ups after you make a PDF.
Cliff Drumeller
Information Technology Manager
Mass Precision Sheetmetal
408 954-0200 ex 217
Sent: Tuesday, April 29, 2003 7:21 AM
Rhonda
<http://us.adserver.yahoo.com/l?M=229633.3212141.4526654.2595810/D=egroupmai
l/S=:HM/A=1556779/rand=309296336>
Try Volo View Express, the free AutoCAD viewer (& redlining tool) from
AutoDesk (www.autodesk.com).
Paul.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, April 29, 2003 3:20 PM
> Thanks
> Rhonda
This e-Mail (and any attachments) should only be read by the intended
addressee(s) and not be relied upon without subsequent written confirmation
of its contents. Concentric Controls Ltd. accepts no liability for the
consequences of any person acting on such information prior to the receipt
of such confirmation. If you are not the intended recipient, you are not
authorised to, and must not use, disclose, copy, distribute, or retain this
message, its attachments or any part thereof. Any views or opinions
expressed are those of the author and do not necessarily reflect the
opinions of Concentric Controls Ltd.
Concentric Controls Ltd. www.concentriccontrols.com
Priory Road, Aston, Birmingham B6 7LH, UK
Tel: +44 (0)121 327 1662 Fax: +44 (0)121 328 2498
Rhonda,
Voloview is ok. I personally like to convert them to a PDF. Pretty easy
with PDFFactory and free.
Dan
Daniel C. Spoerl
Estimator/MIS Manager
Toledo Metal Spinning Co.
Phone: (419) 535-5931 ext. 203
Fax: (419) 535-0565
Personal E-fax: (707) 897-1708
Email: dans@... <mailto:dans@...>
WebSite: http://www.toledometalspinning.com
<http://www.toledometalspinning.com/>
<http://www.toledometalspinning.com/products_configurator.htm>
Sent: Tuesday, April 29, 2003 10:21 AM
Rhonda
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.465 / Virus Database: 263 - Release Date: 3/25/2003
Outgoing mail is certified Virus Free.
We received a program from EPICOR with our Vantage system
Called Auto Vue
Its great it displays ANYTHING AND EVERYTHING I have ever thrown at it
You mihgt check with Vantage
> Thanks
> Rhonda
New release of autoview is Great
Sent: Tuesday, April 29, 2003 11:32 AM
Subject: [Vantage] Re: Document Management
Called Auto Vue
> Thanks
> Rhonda
Check out AcroPlot at http://www.cadzation.com/ . We have all of our
approved AutoCad files automatically converted to PDF. You can put each
view of a cad file on a seperate page in the pdf file. Works great.
Rich
Rhonda
Hi all,
For those of you that have Auto View, How many copies
do you need/have. Auto View was very expensive the last
time I checked.
John Mansfield
General Sheet Metal
Expensive, maybe. Seats required: one. It runs on the server and gets
shelled to each workstation that requires it. It is NOT licensed "per seat
of Vantage." Otherwise, I could never afford it.
Dan Maddox
Pactiv Corp
At 09:49 PM 4/29/2003 +0000, you wrote:
>Hi all,
>time I checked.
>Thanks
>John Mansfield
>General Sheet Metal
Dan,
Sorry to give you bad news but thats not true. Durring a licensing audit we
discovered that if Autovue is installed on the server then a license must be
purchased for each workstation that can open Autovue. Epicor and CIMMETRY
has confirmed this. Below is an e-mail exchange with our sales rep at
Epicor. I am sure I have other e-mails I can share with your about this.
Jeremy Leonard
IT Manager
K-T Corporation
E-mai as Follows:
Since I was not involved in the original sale, I'm not sure what
conversations occurred. But often times, a customer will state that only a
few employees will need to access Autovue, usually engineering, so just that
many seats are purchased. It doesn't sound like the plans you have today to
make documents and drawings available to all users existed when you first
purchased the system?
Let me know what type of timeline you're looking at, and maybe I can do
something on the price?
Michael Holton
e p i c o r S o f t w a r e
Customer Account Manager
eManufacturing Division
Sent: Sunday, December 09, 2001 4:32 AM
To: 'Michael Holton'
Subject: RE: Autovue
Thanks Mike,
Your pricing is much better then going direct. I'm sure my boss is going to
ask the question, "Why did vantage sell us this when we purchased over 30
Vantage licenses with Document Management?" Just asking you so I will have
an answer when he asks me. Our costs will be about $48,000 to become legal
and I'm going to have to explain it.
Jeremy
Sent: Friday, December 07, 2001 4:00 PM
To: Jeremy Leonard (E-mail)
Subject: Autovue
Jeremy, I checked out OEM agreement with Autovue. It appears that if you
want to be compliant, you need to purchase an Autovue license for every
person on the network who has the ability to launch an Autovue license.
The Solid Model version of Autovue goes for $1125 per user, plus you can
upgrade the 5 Autovue licenses you have to the Solid Model version for $700
each.
Michael Holton
Sent: Tuesday, April 29, 2003 7:41 PM
Subject: Re: [Vantage] Document Management
Dan Maddox
Pactiv Corp
>Hi all,
>time I checked.
>Thanks
>John Mansfield
>General Sheet Metal
I like -
FastLook Plus provides fast, accurate viewing of the most popular vector
and raster images, including CAD drawings, scanned documents,
renderings, word processing documents, spreadsheets and even color
photos.
"...it lives up to its name - it's fast."- Paradox Informant Magazine
Supports AutoCAD, Inventor, SolidWorks, MicroStation*, Cadkey, ME 10/30,
DXF, HPGL, TIFF, Cals G4 and much, much more!
Supported Formats <http://www.kamelsoftware.com/fastlook/list.htm>
* - Denotes the need for the DGN Module
<http://www.kamelsoftware.com/fastlook/fastlook.htm>
Features <http://www.kamelsoftware.com/fastlook/overview.htm>
* Overview <http://www.kamelsoftware.com/fastlook/viewover.htm>
* View Over 200 Formats
<http://www.kamelsoftware.com/fastlook/redmark.htm>
* Redline/Markup
<http://www.kamelsoftware.com/fastlook/linking.htm>
* HyperLinking <http://www.kamelsoftware.com/fastlook/print.htm>
* Printing/Plotting
<http://www.kamelsoftware.com/fastlook/flexible.htm>
* Flexible Interface
<http://www.kamelsoftware.com/fastlook/dataext.htm>
* AutoCAD Data Extraction
<http://www.kamelsoftware.com/fastlook/admin.htm>
* Network Admin Control
Integration <http://www.kamelsoftware.com/fastlook/in_ie.htm>
* Inside Internet Explorer
<http://www.kamelsoftware.com/fastlook/in_nets.htm>
* Inside Netscape
<http://www.kamelsoftware.com/fastlook/in_vb.htm>
* Inside Visual Basic
<http://www.kamelsoftware.com/fastlook/in_acc.htm>
* Inside Access
Demonstrations <http://www.kamelsoftware.com/demo.asp>
* Download Demo
I think a site license is something like $1500.
Jeff
Sent: Wednesday, April 30, 2003 7:34 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Document Management
Dan,
licensing audit we
license must be
and CIMMETRY
rep at
about this.
Jeremy Leonard
IT Manager
K-T Corporation
E-mai as Follows:
that only a
so just that
have today to
you first
can do
Michael Holton
Thanks Mike,
is going to
purchased over 30
I will have
become legal
Jeremy
Subject: Autovue
that if you
for every
license.
you can
version for $700
each.
Michael Holton
and gets
licensed "per seat
Dan Maddox
Pactiv Corp
>Hi all,
>time I checked.
>Thanks
>John Mansfield
>General Sheet Metal
<http://rd.yahoo.com/M=232617.3212172.4524785.2595810/D=egroupweb/S=1705
007183:HM/A=1555962/R=0/*http://shop.store.yahoo.com/cgi-bin/clink?1800f
lowers2+shopping:dmad/M=232617.3212172.4524785.2595810/D=egroupweb/S=170
5007183:HM/A=1555962/R=1/1051706319+http://us.rmi.yahoo.com/rmi/http://w
ww.1800flowers.com/rmi-framed-url/http://www.1800flowers.com/cgi-bin/flo
wers/product.pl/MD01e84aF3GROUPSHMYH/1202>
<http://us.adserver.yahoo.com/l?M=232617.3212172.4524785.2595810/D=egrou
pmail/S=:HM/A=1555962/rand=835224209>
You must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
Service <http://docs.yahoo.com/info/terms/> .
