What filters does it have? You need to verify that the filters reflect
information for your company. i.e. if there is a company filter, you need
to change it to your company ID, etc.
I tried download a few of the reports from the main discussion board
site. The reports re supposed to work with Report builder however
for some reason they don not. How do i get them to work? Does
anyone have any ideas?
They are .prl files, correct? What is the error you get?
When you open the reports with report builder you need to change the
connection options to reference your Vantage server and database location.
Then, when the report opens you probably need to modify the filters for your
company.
Anything for report builder should be in a .PRL file (Progress Report Library). You then open the library file and see what report(s) inside.
Very likely the database connection will have to be changed to match your site.
Equally likely filter on company (every RB report should have one) will have to be changed for your company.
If still not working send specifics of problem.
-Todd C.
Sent: Thursday, March 06, 2003 11:30 AM
Subject: [Vantage] Downloadable Rpts from the main board
When the error occurs, select options and change the correct location of
your vantage database X:\Vantage\db\vantage.db (X is the mapped drive to
Epic52 or whatever your epic directory is) Host name should be your Server
name and Services should be EPIC52 if that is the version you are on.
Change filters to reflect your own criteria
