E9 - Checks printing
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Just type in the first number you want and from then on the system will
> auto count.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Mon, Nov 12, 2012 at 11:07 AM, Tim Vonderhaar <
> tvonderhaar@...> wrote:
> > OK, got things working using the free MICR font Jose posted awhile ago
> > from this website. Very simple to setup actually.
> > http://sandeen.net/GnuMICR/
> > One last question. Is there a way to force the check number starting
> > point? I want to be sure we start with a number past our last check number
> > used in our old system.
> > Thanks,
> > Tim
> > --- In vantage@yahoogroups.com, "Tim Vonderhaar" <tvonderhaar@> wrote:
> > > Thanks guys. Should be easy enough to setup.
> > > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > > We do that, just add your account / routing number to your "Account"
> > > > module. And then modify the Check Crystal Report to include this info.
> > > > Epicor comes with a MICR font which you can use on Crystal. Some banks
> > > > require magnetic ink, but some use optical scanners so its up to your
> > bank.
> > > > If they require magnetic ink, you can buy it for most printers. We
> > have a
> > > > dedicated check printer which only certain users have access to.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > On Mon, Nov 12, 2012 at 8:01 AM, brad_boes <bboes@> wrote:
> > > > > We do print our own checks. We bought a special MICR font
> > cartitridge for
> > > > > the printer. This stays in one printer and the office is locked up at
> > > > > night. I know there was a template from our bank that we used to
> > check the
> > > > > layout against. You may want to contact your bank for this
> > information and
> > > > > help.
> > > > > Brad Boes
> > > > > Metalworks
> > wrote:
> > > > > > Does anyone print checks from blank check stock and add the routing
> > > > > number during printing or does everyone use pre-printed check stock?
> > If you
> > > > > do print your own, any tips on adding the data to Crystal?
> > > > > > Thanks,
> > > > > > Tim
> > > > [Non-text portions of this message have been removed]
Does anyone print checks from blank check stock and add the routing number during printing or does everyone use pre-printed check stock? If you do print your own, any tips on adding the data to Crystal?
Tim
We do print our own checks. We bought a special MICR font cartitridge for the printer. This stays in one printer and the office is locked up at night. I know there was a template from our bank that we used to check the layout against. You may want to contact your bank for this information and help.
Brad Boes
Metalworks
> Thanks,
> Tim
require magnetic ink, but some use optical scanners so its up to your bank.
If they require magnetic ink, you can buy it for most printers. We have a
*Jose C Gomez*
*Software Engineer*
E: jose@...
> help.
> Brad Boes
> Metalworks
> > Thanks,
> > Tim
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > help.
> > Brad Boes
> > Metalworks
> > > Thanks,
> > > Tim
OK, got things working using the free MICR font Jose posted awhile ago from this website. Very simple to setup actually.
One last question. Is there a way to force the check number starting point? I want to be sure we start with a number past our last check number used in our old system.
Tim
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > help.
> > > Brad Boes
> > > Metalworks
> > > > Thanks,
> > > > Tim
auto count.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Tim
> bank.
> have a
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> cartitridge for
> check the
> information and
> > > > help.
> > > > Brad Boes
> > > > Metalworks
> If you
> > > > > Thanks,
> > > > > Tim
Tim,
Besides editing Crystal, you will also need a watermark on the checks. I
can't remember if this is hardware or software. The Crystal part should not
be hard.
Cathy
Tim Vonderhaar
Sent: Saturday, November 10, 2012 9:54 AM
Subject: [Vantage] E9 - Checks printing
Tim
Water mark?
We just use "Check Sheets" which come with the water makers and heat
sensitive lock and what not.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, Nov 12, 2012 at 11:18 AM, Cathy <cathy@...> wrote:
> Tim,
> be hard.
> Cathy
> Of
> Tim Vonderhaar
> Thanks,
> Tim
