Email AP Remittance using APR and Data Directive
Hello,
Need some help with emailing AP Remittance using APR and Data Directive. Configured APR and seems to work when manually printing the AP remittance. However, I am trying to use Data Directive to email using the APR rules but getting an error. I am getting ‘A valid AP check group is required’ error.
Data Directive to use APR rule to send an email when payment posting status change from ‘false’ to ‘true’
Double check the parameters in the auto-print widget.
Hi Calvin,
Any thought on which parameter I may need to look. I added Report Parameters for the GroupID but still failing.
Did you figure this out?
