Oh and BTW, the issue goes away when you upgrade to 8.xx.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 a Fax 401-596-1050
www.maxsonautomatic.com <http://www.maxsonautomatic.com/>
_____
Aaron Hoyt
Sent: Wednesday, March 26, 2008 9:47 AM
Subject: Re: [Vantage] Email Global Alerts
You will find there are several free (or shareware) small mail servers
out there (even for Windows OS). They can be installed on a local
sever. You can direct Vantage to the small internal mail server and set
each client to collect from that server as a separate account to collect
from on the client. This is what I had to do before I brought our
hosting in-house. I can't remember the server I used at the time, but
it was rather basic. All you really need is an SMTP/POP3 server that
allows you to create accounts for your users. A quick search for "free
mail server for windows" on Google turns up tons of results. It's
really a very simple thing to set up. The trick is to find one that
will allow the malformed emails from Vantage. I know the exist because
I used one for a couple years.
Best of luck,
Aaron
Stephen Edginton wrote:
Controller
_____
Aaron Hoyt
Best of luck,
Aaron
><mailto:vantage%40yahoogroups.com>
> I had this problem with Microsoft CRM email also.
> You will find that Exchange server (Microsoft SMTP service) does not
> care about the missing \r
> Different MTA's have different policies some allow it through like
> Microsoft SMTP un modified, others fix them others reject them.
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>] On
> Behalf<mailto:vantage%40yahoogroups.com>
> Of Stan Chmura
> Sent: 25 March 2008 19:55
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: RE: [Vantage] Email Global Alertsto/docs/smtplf.html
> Below is the last entry of an old call from 2004. For what it's worth,
> our
> web/email host had a theory of why global alerts ceased to work when I
> upgraded to 6.1. The bottom line (according to our host) is that the
> format of Vantage is inconsistent with industry standards. It came to a
> battle between our host and Epicor, "It's not my problem; it's yours".
> Of
> course that translates to it's MY problem now. It has not been fixed and
> I
> no longer have global alerts.
> David:
> The below is a response from my e-mail host. He has over 100 clients for
> hosting e-mail and web sites. That's all he does. I believe he knows
> what
> he's talking about.
> It's a very simple problem, with a very simple
> solution. Properly terminate the line endings on the outgoing emails
> generated by Vantage: \r\n (carriage return + line feed) instead of just
> a
> line feed (\n). This is written as a STANDARD in the applicable RFCs.
> Just
> because other MTAs may accept a incorrectly formatted email, does not
> mean
> everyone else should.
> For an explanation as to why these emails are rejected by our MTA (which
> is
> qmail), and why you shouldn't "break the rules" (there is a purpose
> behind
> standards) see: http://cr.yp <http://cr.yp.to/docs/smtplf.html>
> <http://cr.yp <http://cr.yp.to/docs/smtplf.html> to/docs/smtplf.html><http://www.ietf <http://www.ietf.org/rfc/rfc0821.txt> org/rfc/rfc0821.txt>
> And also see section 4.1.1 of this document.
> Stan
> _____
> <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> ] On<mailto:vantage%40yahoogroups.com>
> Behalf Of
> richard.hyatt
> Sent: Tuesday, March 25, 2008 1:47 PM
> <mailto:vantage%40yahoogroups.com>[Non-text portions of this message have been removed]
> Subject: [Vantage] Email Global Alerts
> We just changed over from hosting our on website to a third parts
> hosting it for us. I can not receive any global alerts. When I force
> a tick it gets hung up. I am using vantage 6.10.
