Just go into proexp, expand your name server folder, right click on your
name server and check the properties.
Once your in the properties section, the help program will give you all the
information you need to set it up.
It's pretty well defined there for you.
Good luck!
Although...I'm starting to lean toward the firewall port idea if you have
one between the sites...
________________________
Jim Kennedy
Manager, Information Technologies
Firstmark Aerospace
921 Holloway St.
Durham, North Carolina 27701
Office: (919) 956-4264
FAX: (919) 682-3786
Cell: (919) 697-9410
jkennedy@...
www.firstmarkaerospace.com
www.firstmarkcorp.com
bruce.hoversland@...]
Sent: Friday, September 09, 2005 2:26 PM
To:
vantage@yahoogroups.com
Subject: RE: [Vantage] Multi Company Process server
I haven't done that, could you elaborate on how to do that
jkennedy@...]
Sent: Friday, September 09, 2005 11:17 AM
To:
Another quick thought...you also might have to create another remote or
neighboring name server in proexp if you haven't already.
Jim Kennedy
Firstmark Aerospace
921 Holloway St.
FAX: (919) 682-3786
jkennedy@...
Sent: Friday, September 09, 2005 2:10 PM
To:
I will try that and let you know
jkennedy@...]
Sent: Friday, September 09, 2005 11:02 AM
To:
You might try increasing the delay on the failed db connect for the remote
site.
Have you tried adjusting the delays at all?
Jim Kennedy
Firstmark Aerospace
921 Holloway St.
FAX: (919) 682-3786
jkennedy@...
Sent: Friday, September 09, 2005 1:43 PM
To:
Here are my settings I do have 2 process servers one for each DB port, the
processor server on the near will start fine
DelayGlobalAlerts=00:00:30
DelayMultiCompany=00:00:30
DelayExternalFinancials=00:00:30
DelayGenericImport=00:00:30
DelayGlobalCreditCheck=00:00:30
DelayFailedDBConnect=5
jkennedy@...]
Sent: Friday, September 09, 2005 10:36 AM
To:
What are your process server .mfg file settings for the following...
DelayMobileConnectServer=00:00:30
DelayMobileConnectSync=00:00:30
When you're referring to the port number below are you talking about the DB
port number?
If so, you could create and run a second (separate) process server file to
run specifically for that port number with the necessary port / delay
settings required for the remote site.
Jim Kennedy
Firstmark Aerospace
921 Holloway St.
FAX: (919) 682-3786
jkennedy@...
Sent: Friday, September 09, 2005 1:16 PM
To:
Subject: [Vantage] Multi Company Process server
I am trying to set up global parts in a Multi Company setting. We have a vpn
connection between the 2 sites and I can map the drive on the far end.
Both
companies have been set up in ext comp maintenance I changed the port number
at one location so will have different port numbers for each location and
the service file reflects the ports on both ends. When I try to start the
process server for the far end it times itself out. Does anyone have any
ideas?
------------------------ Yahoo! Groups Sponsor --------------------~--> Fair
play? Video games influencing politics. Click and talk back!
http://us.click.yahoo.com/T8sf5C/tzNLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
