Guys,
Found this out the hard way when we upgraded to 6.1. Go into
Engineering workbench and click on the magnifying glass next to
group. Highlight a group and click update. Do not Double click on
it as that will not let you change it. The ECO group maintenence
screen will appear. Change the desription name just slightly. Say
if it said "plant floor" make it "plant floor2" Click ok. Make
sure you click ok. That should get the "check in allowed" check box
to be checked. You can update the same group again and see the
check box in the lower left corner. You must do this to ever group
you have that you want to be able to check in. Hope that made sense.
Shari
Shari
