EpiCombo with UserCodes going Blank on Click
only one has the problem - interesting. Please ensure that all the DropDown and Type property settings are the same for all the Combos and then create a new Tech Support case and send me the number.
@Rich I had a 1.5 hour session with support yesterday, they took loads of information. The case # is CS0001401754.
For anyone that is interested, the problem case that was created in regards to my support call is PRB0210947. So far I have not heard back since it was created.
@Rich @Mark_Wonsil
Hi
Did you try making [RetrieveOnActivate] = False?
10.2.300.16 Release Notes:
Cool. That should be on next week’s monthly update then.
I found this thread after running into something similar in 10.2.100.36. We’re planning to upgrade soon, so I’ll see if the problem still exists in the newer version.
I followed the instructions in this thread to put a combo box in a grid. The combo box already existed elsewhere in the form. Both combos initially look correct, and both save the correct values when changed and saved. But when the combo in the grid is changed, the original sometimes goes blank. Sometimes it refreshes if you switch tabs a few times, sometimes not.
