Epicor 9.05 rework Process
Exactly, you accept the DMR as material to the rework job. That brings the DMR costs into the rework job as a material cost and the rework processes are labor and burden. If any additional materials are required they are issued to the rework job as usual.
Charlie Smith
CTCharlie@...
Cell: 860-919-1708
Office: 817-862-9862
Sent: Wednesday, June 03, 2015 6:32 AM
Subject: Re: [Vantage] Epicor 9.05 rework Process
How do you accept the DMR to the rework job?  When testing I found that when accepting the DMR at the operation the Job that it was non-conformed at auto populates and it can't be changed.  When accepting at the material I can change the Job to the rework job#.  We non-conform a lot of our stuff through the operation.
Melissa
On Tuesday, June 2, 2015 11:57 AM, "Charlie Smith ctcharlie@... [vantage]" <vantage@yahoogroups.com> wrote:
As a general rule, I would create a rework job as “RW”+DMR number and then accept the DMR to the rework job (Your #5). At that point, the DMR can be closed (Your #6). There should be no $ in the DMR. Once the RW job is finished there should be no other issues. If a corrective action is issues at the time of the Inspection failure, the CAR would indicate the actions taken and the audit can review the RW job to validate that and any other corrective actions were performed.
Charlie Smith
Cell: 860-919-1708
Sent: Monday, June 01, 2015 12:25 PM
To: Vantage List
Subject: [Vantage] Epicor 9.05 rework Process
We would like to change the way that we handle reworks within Epicor.
We have issues due to DMR's hanging open for several weeks/months, which means that the Job's will stay open this long.
The process we currently use is below,  if there is anything that we could do differently please let me know.  I feel like we are making this harder than what it really needs to be.
1.) An operator will non-conform a part either while ending their labor activity or through the Non-Conformance entry screen.
2.) A tag will then be turned into Quality.
3.) Quality will then fail the part within the Inspection Processing entry screen, this will produce a DMR#
4.) Quality will process the DMR within the DMR Processing entry screen.
5.) A rework Job is created (Job Number is generated outside of Epicor).  Operations are added, but nothing else.
6.) When the rework is completed Quality closes the DMR.
Is there a simpler way of doing this?
Melissa
Melissa
Charlie Smith
CTCharlie@...
Cell: 860-919-1708
To: Vantage List
Melissa
Melissa
<div id="ygrps-yiv-2110889982yiv1306787798ygrp-text">
  <div></div><div class="ygrps-yiv-2110889982yiv1306787798WordSection1"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">As a general rule, I would create a rework job as “RW”+DMR number and then accept the DMR to the rework job (Your #5). At that point, the DMR can be closed (Your #6). There should be no $ in the DMR. Once the RW job is finished there should be no other issues. If a corrective action is issues at the time of the Inspection failure, the CAR would indicate the actions taken and the audit can review the RW job to validate that and any other corrective actions were performed.</span></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Charlie Smith</span></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">CTCharlie@...</span></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Cell: 860-919-1708</span></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Office: 817-862-9862</span></div></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div><div style="padding:3pt 0in 0in;border-top-color:rgb(181, 196, 223);border-top-width:1pt;border-top-style:solid;"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><b><span style="font-size:10pt;">From:</span></b><span style="font-size:10pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <br clear="none"><b>Sent:</b> Monday, June 01, 2015 12:25 PM<br clear="none"><b>To:</b> Vantage List<br clear="none"><b>Subject:</b> [Vantage] Epicor 9.05 rework Process</span></div></div></div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"> &nbsp;</div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal">&nbsp; </div><div id="ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg"><div id="ygrps-yiv-2110889982yiv1306787798ygrp-msg"><div id="ygrps-yiv-2110889982yiv1306787798ygrp-text"><div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_4903"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>We would like to change the way that we handle reworks within Epicor.&nbsp; </span></div></div><div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>We have issues due to DMR&#39;s hanging open for several weeks/months, which means that the Job&#39;s will stay open this long.</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5692"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5693"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>The process we currently use is below,&nbsp;&nbsp;if there is anything that we could&nbsp;do&nbsp;differently please let me know.&nbsp; I feel like we are making this harder than what it really needs to be.</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5565"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_4912"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>1.) An operator will&nbsp;non-conform a part either while ending their labor activity or through the Non-Conformance entry screen.&nbsp; </span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5604"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>2.) A tag will then be turned into Quality. </span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5608"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>3.) Quality will then fail the part within the Inspection Processing entry screen, this will produce a DMR#</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5620"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>4.)&nbsp;Quality will process the DMR within the DMR Processing entry screen.&nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5649"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>5.) A rework Job is created (Job Number is generated outside of Epicor).&nbsp; Operations are added, but nothing else.</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5671"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>6.) When the rework is completed Quality closes the DMR.</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5723"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5724"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>Is there a simpler way of doing this?</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5739"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5740"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5745"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>Thanks,</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5746"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span>Melissa</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5690"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5691"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5577"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div><div id="ygrps-yiv-2110889982yiv1306787798yui_3_16_0_1_1433156055230_5592"><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal" style="background:white;"><span> &nbsp;</span></div></div></div></div><div><div class="ygrps-yiv-2110889982yiv1306787798MsoNormal"><span style="color:white;"></span></div></div></div></div></div>
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798 -- #ygrps-yiv-2110889982yiv1306787798ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp #ygrps-yiv-2110889982yiv1306787798hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp #ygrps-yiv-2110889982yiv1306787798ads {
margin-bottom:10px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp .ygrps-yiv-2110889982yiv1306787798ad {
padding:0 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp .ygrps-yiv-2110889982yiv1306787798ad p {
margin:0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mkp .ygrps-yiv-2110889982yiv1306787798ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ygrp-lc {
font-family:Arial;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ygrp-lc #ygrps-yiv-2110889982yiv1306787798hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ygrp-lc .ygrps-yiv-2110889982yiv1306787798ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity span {
font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity span span {
color:#ff7900;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798activity span .ygrps-yiv-2110889982yiv1306787798underline {
text-decoration:underline;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798attach div a {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798attach img {
border:none;padding-right:5px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798attach label a {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798bold a {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 dd.ygrps-yiv-2110889982yiv1306787798last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 dd.ygrps-yiv-2110889982yiv1306787798last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 dd.ygrps-yiv-2110889982yiv1306787798last p span.ygrps-yiv-2110889982yiv1306787798yshortcuts {
margin-right:0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798attach-table div div a {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798attach-table {
width:400px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798file-title a, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798file-title a:active, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798file-title a:hover, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798file-title a:visited {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798photo-title a, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798photo-title a:active, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798photo-title a:hover, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div.ygrps-yiv-2110889982yiv1306787798photo-title a:visited {
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 div#ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg #ygrps-yiv-2110889982yiv1306787798ygrp-msg p a span.ygrps-yiv-2110889982yiv1306787798yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798green {
color:#628c2a;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 o {
font-size:0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798photos div {
float:left;width:72px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798reco-category {
font-size:77%;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798reco-desc {
font-size:77%;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 .ygrps-yiv-2110889982yiv1306787798replbq {
margin:4px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg select, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 input, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg pre, #ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 code {
font:115% monospace;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-mlmsg #ygrps-yiv-2110889982yiv1306787798logo {
padding-bottom:10px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-msg p#ygrps-yiv-2110889982yiv1306787798attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-reco #ygrps-yiv-2110889982yiv1306787798reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-sponsor #ygrps-yiv-2110889982yiv1306787798ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-text {
font-family:Georgia;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-text tt {
font-size:120%;}
#ygrps-yiv-2110889982 #ygrps-yiv-2110889982yiv1306787798 #ygrps-yiv-2110889982yiv1306787798ygrp-vital ul li:last-child {
border-right:none !important;}
