<div id="ygrps-yiv-990972205yiv0757716451ygrp-text">
<div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">Normally a DMR removes the part(s) from the job and inspection decides the next step. Quality Control, QC, should be working with the production team on the issue in order to correct it from happening again. </div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">Now once the part(s) is removed from the job and a DMR is issues another job is issued and linked to the original job to replace it to fulfill demand. This job would be your Re-Work job. The rework job can be to fix the part, or make a whole new one depending on the issue.</div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"> If the job was run complete and there's enough parts to meet demand then a Corrective Action is issued and QC watches the next time this job is run for similar issues. </div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">One part doesn't stop a job unless the job = 1 part. The job can still run with a rework job linked to the original job to meet demand.</div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">So for example I have 100 parts in Job 0001. Demand is for 100 parts.</div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">2 are marked bad due to chipping in the paint. A DMR is issued. 2 parts are sent back to paint on rework job num RW-0001 that is linked to Job num 0001.</div><div dir="ltr" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">98 parts are complete on Job 0001. </div><div dir="ltr" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304"><br clear="none"></div><div dir="ltr" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9304">When RW-0001 is complete I will have 100 parts to fulfill demand and ship to customer. </div><div></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9351"> </div><div class="ygrps-yiv-990972205yiv0757716451signature" id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9353"><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9352"><span id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9469" style="color:rgb(0, 0, 255);"><span id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9468" style="background-color:rgb(255, 255, 255);"><span id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9467" style="font-weight:bold;">Jonathan Lang</span></span></span><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9354" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><span style="font-weight:bold;">I.T Manager</span></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9355" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><span style="font-weight:bold;">Database Engineer</span><br clear="none"></div><div id="ygrps-yiv-990972205yiv0757716451yui_3_16_0_ym19_1_1471286946706_9356" style="color:rgb(0, 0, 0);font-size:13px;font-family:arial, helvetica, clean, sans-serif;background-color:transparent;font-style:normal;"><br clear="none"></div></div></div>
</div>
<div style="color:#fff;min-height:0;"></div></div>
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451 --
#ygrps-yiv-990972205yiv0757716451ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp #ygrps-yiv-990972205yiv0757716451hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp #ygrps-yiv-990972205yiv0757716451ads {
margin-bottom:10px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp .ygrps-yiv-990972205yiv0757716451ad {
padding:0 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp .ygrps-yiv-990972205yiv0757716451ad p {
margin:0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mkp .ygrps-yiv-990972205yiv0757716451ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ygrp-lc {
font-family:Arial;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ygrp-lc #ygrps-yiv-990972205yiv0757716451hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ygrp-lc .ygrps-yiv-990972205yiv0757716451ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity span {
font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity span span {
color:#ff7900;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451activity span .ygrps-yiv-990972205yiv0757716451underline {
text-decoration:underline;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451attach div a {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451attach img {
border:none;padding-right:5px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451attach label a {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451bold a {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 dd.ygrps-yiv-990972205yiv0757716451last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 dd.ygrps-yiv-990972205yiv0757716451last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 dd.ygrps-yiv-990972205yiv0757716451last p span.ygrps-yiv-990972205yiv0757716451yshortcuts {
margin-right:0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451attach-table div div a {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451attach-table {
width:400px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451file-title a, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451file-title a:active, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451file-title a:hover, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451file-title a:visited {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451photo-title a, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451photo-title a:active, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451photo-title a:hover, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div.ygrps-yiv-990972205yiv0757716451photo-title a:visited {
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 div#ygrps-yiv-990972205yiv0757716451ygrp-mlmsg #ygrps-yiv-990972205yiv0757716451ygrp-msg p a span.ygrps-yiv-990972205yiv0757716451yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451green {
color:#628c2a;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 o {
font-size:0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451photos div {
float:left;width:72px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451reco-category {
font-size:77%;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451reco-desc {
font-size:77%;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 .ygrps-yiv-990972205yiv0757716451replbq {
margin:4px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg select, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 input, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg pre, #ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 code {
font:115% monospace;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-mlmsg #ygrps-yiv-990972205yiv0757716451logo {
padding-bottom:10px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-msg p#ygrps-yiv-990972205yiv0757716451attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-reco #ygrps-yiv-990972205yiv0757716451reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-sponsor #ygrps-yiv-990972205yiv0757716451ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-text {
font-family:Georgia;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-text tt {
font-size:120%;}
#ygrps-yiv-990972205 #ygrps-yiv-990972205yiv0757716451 #ygrps-yiv-990972205yiv0757716451ygrp-vital ul li:last-child {
border-right:none !important;}
