Epicor 9.06.700C DMT Tool - Cost Adj
Thanks very much!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Phil Collier
Sent: Friday, March 14, 2014 3:44 PM
Subject: [Vantage] Re: Epicor 9.06.700C DMT Tool - Cost Adj
I found that when you DMT cost Adjustments, it over writes the current cost in the table. If the cost is the same as the cost that exists in the table it gives you an error stating: "No Unit Costs have been changed. Make adjustment or cancel". So the "Add New" is basically an update to a temporary table.
-Phil
Phil Collier | Application Software Specialist
[cid:image001.jpg@01CF3F93.1AAD2150]
Dynomax Inc. | Design * Manufacturing * Performance
1535 Abbott Drive, Wheeling, IL 60090| www.dynomaxinc.com<http://www.dynomaxinc.com/>
Main: 847.680.8833 | Direct: 224.207.7657 | Fax: : 847.680.8838
This electronic message transmission is intended only for the use of the person to whom it is addressed, including any attachments, and contains information from Dynomax Inc, which may be privileged, competition sensitive, confidential, or protected by law. If you are not the intended recipient, you are hereby notified that any dissemination, copying or distribution of this email or its contents is strictly prohibited. If you have received this message in error, please notify us immediately by replying to the message and deleting it from your computer.
ITAR Notice: This email may contain technical data which may be controlled by the US International Traffic in Arms Regulation (ITAR) 22 CFT part 120-130. If this data is determined to be ITAR controlled, such data may not be transmitted, shared or provided to any foreign party or entity either verbally or visually without proper licenses from the State Department. It is your responsibility to assure this item can by legally shared with another party. Thank you for your compliance.
I am trying to use the DMT ToolèInventoryècost Adjustment to update the Standard Material Cost on our raw materials.
However, when I open the input file, it only gives me the option to 'Add New'.
Anyone out there have any idea why? I want to change the material cost and then do a cost rollup.
Regards,
Bill Turgeon
Director, Information Technology
Coto Technology, Inc.
66 Whitecap Drive
North Kingstown, RI 02852
Ph: 401-583-7223
Cell: 401-368-9938
Fax: 401-942-0920
E-mail: bturgeon@... <mailto:jbentley@...>
P Please consider the environment before printing this email.
This e-mail and any attachments are for the sole use of the intended recipients and may be privileged or confidential. Any distribution, printing or other use by anyone else is prohibited. If you are not an intended recipient, please contact the sender immediately, and permanently delete this e-mail and attachments.
-Phil
