We've used it for a number of years with very little problems. The only problem I can think of is the format of the W2 text file to be electronically filed with our state. The state total record needs to be entered manually. Also, our state's software checks the date of first hire and termination date for correct syntax (don't ask me why the state needs that info!). In Vantage at least, I haven't checked Epicor 9 yet, those dates are stored as MMDDYY. The federal guide shows the syntax should be MMDDYYYY. As we only have a little over a hundred employees it hasn't been a big deal to modify the dates manually using Notepad in order to keep our state happy. One thing on our enhancement wish list is for the payroll check to be a Crystal report so we can modify it. All the prep time for payroll that would need to be done whether payroll is in house or outsourced is the same. Once all the prep work is done it takes very little time to actually process the payroll. Vantage payroll works well for us.
Sue
Sue
--- In vantage@yahoogroups.com, "Mike Tonoyan" <mtonoyan@...> wrote:
> Hello,
> We are considering using Epicor Payroll module vs. outsourcing it to
> well known three letter payroll services company. How many companies use
> Epicor Payroll module and what is your opinion?
> Thank you in advance.
> Mike Tonoyan / Natel EMS
> mtonoyan@...
> ______________________________________________________________________
> Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
