Epicor Cloud Unable to Connect from Terminal Server
can somen help with this please
terminal server cant connect to cloud
other pc works fine
Application Error
Exception caught in: mscorlib
## Error Detail ##
##!Message:##! An error occurred while making the HTTP request to https://uksouthdtapp02.epicorsaas.com/SaaS520/Ice/Lib/SessionMod.svc. This could be due to the fact that the server certificate is not configured properly with HTTP.SYS in the HTTPS case. This could also be caused by a mismatch of the security binding between the client and the server.
##!Inner Exception Message:##! The underlying connection was closed: An unexpected error occurred on a send.
##!Program:##! CommonLanguageRuntimeLibrary
##!Method:##! HandleReturnMessage
## Client Stack Trace ##
Server stack trace:
   at System.ServiceModel.Channels.HttpChannelUtilities.ProcessGetResponseWebException(WebException webException, HttpWebRequest request, HttpAbortReason abortReason)
   at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.WaitForReply(TimeSpan timeout)
   at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout)
   at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityRequestChannel.Request(Message message, TimeSpan timeout)
   at System.ServiceModel.Dispatcher.RequestChannelBinder.Request(Message message, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   at Ice.Contracts.SessionModSvcContract.Login()
   at Ice.Proxy.Lib.SessionModImpl.Login()
   at Ice.Core.Session.InitSessionMod(String asUrl, Boolean fwVerCheck, String companyID, String plantID)
   at Ice.Core.Session.InitSession(Action setCredentials, String asUrl, LicenseType licenseType, String pathToConfigurationFile, Boolean fwVerCheck, String companyID, String plantID, Boolean useChannelCacheForServices)
   at Ice.Core.Session..ctor(String userID, String password, String asUrl, LicenseType licenseType, String pathToConfigurationFile, Boolean fwVerCheck, String companyID, String plantID, Boolean useChannelCacheForServices)
   at Ice.Core.Session..ctor(String userID, String password, LicenseType licenseType)
   at Ice.Lib.LogOn.CreateSession(String userID, String password, String appServerUri, LicenseType licenseType, SessionTokenType sessionTokenType, Object azureADOwnerWindow)
   at IceShell.Apps.LogonDialog.logOn(String userID, String password, Boolean promptUpdatePassword)
   at IceShell.Apps.LogonDialog.DoWorkLogon()
## Inner Exception ##
   at System.Net.HttpWebRequest.GetResponse()
Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
Is this a new problem? Or is this the first time you are trying to use it via the TS?
hi
user deployed client to pc …and all worls fine
also installed on TS and . off line…
Peter
Have you tried reinstalling on the TS? Can any user on the TS access Epicor?
We currently have this problem… can you elaborate on how you fixed this? thanks
Hi could you elaborate please thanks
What version is your TS? Your TLS level has to be upgraded to connect to Epicor SaaS.
