100000000% agreed
they should use the software as their ERP/CRM solution rather than just sell the software, then it would work correctly.
Gonna have to gently push back here a bit.
Listening to customers is WHY there are so many changes. We canât get ten people to agree here on this list let alone thousands.
Trying to please many companies can lead to oscillating changes if one isnât careful.
Epicor is âkeeping upâ with an online version of the documentation. This is how pretty much all software companies run. Microsoft generates a PDF every time it generates the help files, so it can be done. But what about the versions downloaded? Theyâre out of date.
How quickly does the documentation and marketing materials get changed at your companies after an ECO?
What happens to all the printed versions out there? Do you collect them from the customers?
The XY problem is a little different. There is a problem X and we think we have a solution Y. Trying to implement Y becomes âthe problem.â Sometimes, we want solutions Y without knowing what the current problem (X) is. Thereâs probably a different name for that⌠Y Oh Y maybe⌠![]()
How is there not a badge for dad jokes?
Well, basically never; we are engineer-to-order, so itâs kind of a different ballgame there â any marketing material is very generic.
Itâs more the internal struggle of revisions. That process is very slow and everyone hates all of it. Too slow, too fast, no one held my hand and told me exactly how to do my job for this exact ECO, etc.
But replacing that with engineering changes that no one knows about is not the solution.
Or replacing it with Revision 1,425.3 (moved iso view 4 mm to the left) creates so much noise that substantive revisions get ignored along with all the other tweets.
Point is, Iâd argue the same for software docs. Capturing a batch of changes periodically is better than a living document, IMHO. I like slow deliberate change.
Iâve already lost this fight. I know. The cheese is already moved.
And now you got a badge to prove it ![]()
So getting back to the lactose free subject of the treadâŚ
Maybe I am an anomaly but the PDF is huge difference over the web version of the documentation. Most times, I donât know what I donât know. The PDF gives you a start to finish discussion of the software or area. Many times there are parts of CRM or plant maintenance, for example, that I did not consider were covered in the software.
With hyperlinks it is much tougher to go from start to finish when it is endless clicking.
I asked where these were when Kinetic rolled out and the Epicor staff were indifferent to this. When you know the software like the back of your hand then to just click on one subject is not a big deal. If you want a good overview the PDF is very helpful.
Thatâs for sure. It really is absurdly hard to go to the next subtopic in a topic. It is a barrier to learning that forces a user to just give up.
Have you ever looked at a website to see how many people make it past the home page or more than 2 pages in? The drop-off in interest is severe. So web design is much more focused on continuous scroll now.
PDFs are continuous scroll. I guess if an interactive version could do that, too, then OK fine, dump the PDF.
To be clear, there is nothing inherently bad about a PDF. The issue with anything printed (and PDF is a print), is that it is locked in time. If youâre interested in preserving history, thatâs cool but if youâre looking for the most up-to-date information, then not so much.
I think Microsoft Docs has found the happy place: an online version that accepts feedback/changes (via GitHub) and a printable version that is created EVERY TIME a new online version is released.
In the upper-left, there is a topic index for the entire site, which can be filtered. This covers all the pages on this Main Topic.
In the upper right, there is a search index built for this site on every build.
Below that is an Article index to jump to sections âbelow the foldâ
Next to that is a pencil that takes you to GitHub for the source code of the page. You can make an suggested edit (Pull Request) and if accepted, the system rebuilds the site with your changes.
Finally, in the lower left, is the option to download a PDF version of the site. This is NOT a File | Print version of the site. It uses a Markdown to PDF tool to layout a real document that contains all of the same links available online. As mentioned above, this PDF is built at the same time the site is built so it is always up-to-date.
Iâm impressed. Journalism lingo. My mother who has worked at the local paper for two decades would be proud.
Thanks Mark. This was quite helpful. I tried to use a similar method when Microsoft incorporated PDF download into SQL books online a number of years ago.
My one caveat on this is that a PDF that strings together a number of reference documents is different than a document that is intended to reach a conclusion of having a a module implemented or a part of the system (e.g. part master) understood.
The ICE manual is like this with the BAQ reference information and then examples toward the end. I trust they have kept the examples and updated them.
With the rollout of Kinetic I was hoping to download some documents like the the classic PDFs and review them cover to cover offline. Application Studio is one that I really miss this for.
I need to take Joseâs advice and review the online documentation more closely to see how I can reach my goal. I suspect I am not alone in trying to keep my present classic environment going while trying to learn the new approaches in Kinetic on a limited timeframe and this change only extends the time to learn it.
