We are running Epicor 10.2.500.33. Using the Account Budget to import an excel budget document. I am getting the following error message each time:
| 349437 | 1 | 1/17/2022 2:53:03 PM | True | Could not find a part of the path ‘C:\EpicorData\Users\Asmar\Import\test.xlsx’. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share) at Erp.Internal.GL.BudgetImportProcess.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ERP\RL10.2.500.0\Source\Server\Internal\GL\BudgetImportProcess\BudgetImportProcess.cs:line 126 | ServerError |
| 349437 | 2 | 1/17/2022 2:53:03 PM | False | Process is completed with errors. | ServerInfo |
Verified the file was uploaded successfully, but was not processed:
Also confirmed the folder c:\EpicorData has “Everyone” granted with full access.
