Got this in an email today, I am not looking to move ATM but maybe one of
you is? Either way don't contact me directly as I don't know anything about
the position except what is posted. Contact the person at the bottom of the
email
Good Luck
Sr. Epicor Specialist or not so Senior J****
Most important skills are Vantage 8.03 OpenEdge, the ability to write CLEAN
SQL queries, etc****
The main responsibilities is to take over day to day operations thoroughly
understand the system extract data and importto do mass changes, data
loadting not just doing BAQ Dashboards.****
Everything below is NOT required but the more the better.****
An Epicor expert to handle day to day system stability and performance
optimization for a highly customized system in a high volume lean
manufacturing environment. Determine requirements, solutions and execution
of process improvements as it relates to EPR activities. Must be able to
multi-task with good communication skills.
Specialized knowledge, expertise and or abilities concisely required.
B.S. in Computer Science/ Software Engineering.
Preferred Master degree in CS or related field
3 plus years Epicor Vantage 8.03.4xx and/or Epicor 9.05 in a manufacturing
environment.
3 plus years DBA experience with Microsoft SQL Server 2005/2008 including
data warehouse design
CRM, AMM, Engineering, QA, SRM, EDI MRP, Multi-Site AR/AP/GL modules
Progress OpenEdge configuration and optimization including Sonic MQ
Expert with Advanced and Embedded Customizations primarily with BPM
(Progress 4GL) and .Net
Custom form design, BAQ, dashboards, executive dashboards, DMT tool
Though knowledge of Epicor datasets and client server dataflow
Product Configurator
Epicor Service Connect Workflows and Web Services development and execution
Crystal Report writer with Report Data Definitions and configuration with
Altec, APM
Epicor Portal and MS Sharepoint development and administration
Citrix, Customer/Supplier Connect, Agile Manifest CorVu and FRx a plus
Len Bourdette********
Talent Executive****
Kforce Technology Staffing ****
203.225.1714 Office****
203.417.8500 Cell****
203.225.1770 Fax****
lbourdette@...
Good Luck
environment.
Altec, APM
lbourdette@...
