EpiUsers.help Insights 2022 Panel Presenters
Sorry, I think my first question got buried in the room size discussion. Is anything being posted to these forums that was discussed as possibly being posted during the breakout sessions?
I did find this post by reading the note @josecgomez had in one of his slides:
Class to Kinetic Upgrade Helper - Kinetic 202X - Epicor User Help Forum (epiusers.help)
Here are the guts of it - I need to sanitize before I share the whole project but these are the most important bits:
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.Web;
 public static class Zebra
        public static ZebraStatus GetStatus(string name)
            // Printer IP Address and communication port
            string ipAddress = name;
            int port = 9100;  //the default, did you change it?
            // ZPL Command(s)
            string ZPLString = "~HS";
            /*"^XA" +
            "^FO50,50" +
            "^A0N50,50" +
            "^FDHello, World!^FS" +
            "^XZ";*/
            try
                // Open connection
                System.Net.Sockets.TcpClient client = new System.Net.Sockets.TcpClient();
                Stopwatch stopWatch = new Stopwatch();
                stopWatch.Start();
                client.SendTimeout = 3000;
                client.ReceiveTimeout = 5000;
                var success = client.ConnectAsync(ipAddress, port).Wait(1800); //conn timeout
                if (!success)
                    // throw new Exception("Failed to connect.");
                    var resp2 = new ZebraStatus();
                    resp2.Name = name;
                    return resp2;
                // Write ZPL String to connection
                System.IO.StreamWriter writer =
                new System.IO.StreamWriter(client.GetStream());
                writer.Write(ZPLString);
                writer.Flush();
                var ns = client.GetStream();
                var buflen = client.Available;
                var attempts = 0;
                while (buflen == 0 && attempts++ < 20)
                    System.Threading.Thread.Sleep(10);
                var mybuf = new byte[buflen];
                //ns.Read(mybuf, 0, (int)ns.Length);
                var cnt = 0;
                var abort = false;
                while (cnt < buflen && !abort)
                    int val = ns.ReadByte();
                    if (val == -1)
                        abort = true;
                    mybuf[cnt++] = (byte)val;
                var time = stopWatch.ElapsedMilliseconds;
                stopWatch.Stop();
                // Close Connection
                ns.Close();
                writer.Close();
                client.Close();
                //client.EndConnect(clientConn);
                var resp = System.Text.Encoding.ASCII.GetString(mybuf);
                var status = new ZebraStatus();
                status.LoadFromString(resp);
                status.Name = ipAddress;
                status.ResponseTime = time;
                //PrinterResponse.Text = status.ToString();
                return status;
            catch (Exception ex)
                var resp = new ZebraStatus();
                resp.Name = name;
                //PrinterResponse.Text = resp.ToString();
                return resp;
                //throw;
                // Catch Exception
    public class ZebraStatus
            //030,0,0,1244,000,0,0,0,000,0,0,0
            //comm, paperout,pause, labellen, formats, BUFF FULL, Diagnostics, PartialFormat, 3 0's, crpt ram, temp under, temp over
            //001,0,0,0,1,2,6,0,00000000,1,000
            //Func, unused, head open, ribbon out, thermal mode, print mode, print width, label waiting, labels remaining (8), 1, num of images(3)
            //0000,0
            //ignore
            public string Name;
            public string IP;
            public bool PaperOut;
            public bool Paused;
            public bool BufferFull;
            public bool Diagnostics;
            public bool PartialFormat;
            public bool CorruptRam;
            public bool OverTemp;
            public bool UnderTemp;
            public bool HeadOpen;
            public bool RibbonOut;
            public bool ThermalTransfer;
            public int PrintMode;
            public bool LabelWaiting;
            public bool Connected = false;
            public long ResponseTime = 0;
            public bool IsOnline = false;
            public DateTime LastUpdate = DateTime.Now;
        public DateTime? LastResponse = null;
        public bool IsQuerying = true;//false;
            public bool LoadFromString(string input)
                var statuslist = input.Split(',');
                try
                    PaperOut = statuslist[1] == "1";
                    Paused = statuslist[2] == "1";
                    BufferFull = statuslist[5] == "1";
                    Diagnostics = statuslist[6] == "1";
                    PartialFormat = statuslist[7] == "1";
                    CorruptRam = statuslist[8] == "1";
                    OverTemp = statuslist[9] == "1";
                    UnderTemp = statuslist[10] == "1";
                    HeadOpen = statuslist[13] == "1";
                    RibbonOut = statuslist[14] == "1";
                    ThermalTransfer = statuslist[15] == "1";
                    PrintMode = Convert.ToInt32(statuslist[16]);
                    LabelWaiting = statuslist[17] == "1";
                    IsOnline = true;
                    IsQuerying = false;
                    LastResponse = DateTime.Now;
                catch(Exception e)
                    Connected = false;
                    return false;
                Connected = true;
                return true;
            public override string ToString()
                string n = Environment.NewLine;
                string response = this.Connected ?
                    $"Name: {this.Name}{n}ResponseTime(ms):{this.ResponseTime}{n}Paused:{this.Paused}{n}PaperOut:{this.PaperOut}{n}BufferFull:{this.BufferFull}{n}HeadOpen:{this.HeadOpen}{n}RibbonOut:{this.RibbonOut}{n}LabelWaiting:{this.LabelWaiting}{n}" :
                    $"Name: { this.Name}{n}Not Connected!";
                return response;
----- USAGE-----
ZebraStatus status = Zebra.GetStatus(PrinterIPorHostName);
Give me a bit and I’ll share the project (with the disclaimer I am not a webdev)
