Error - Unexpected end of file has occurred. Crystal report
And, as always, if you are having unexpected problems, check your
Vantage server.log file to make sure something weird isn't happening
when the report runs.
-bws
Of Kevin Simon
Sent: Monday, January 10, 2011 9:33 AM
Subject: RE: [Vantage] Error - Unexpected end of file has occurred.
Crystal report
Sounds like you've got only a partial XML file. I'd try rerunning it,
see
if it's an oddball error that doesn't reoccur. If so, look at the XML
file
in your EpicorData/reports area with an editor, and see if it looks
complete.
Kevin Simon
Of
cooner_55421
Sent: Sunday, January 09, 2011 7:25 PM
Subject: [Vantage] Error - Unexpected end of file has occurred. Crystal
report
Hi,
I'm trying to find any info about this error:
"Unexpected end of file has occurred. The following elements are not
closed:
Part, ReportDataSet. Line 4463065, position 1".
This error occurs from a copy of the Time Phase report I'm trying to
make. I
haven't done much to it yet:
- New RDD - copy of TimePhase -
--- added the Part table,
--- linked to the Company table, relationship field company
- New Style - copy of the TimePhase.rpt using the new RDD.
When I run it, teh .xml file grows to 141000 kb and then stops.
I have not found anything in any logs I've looked at so far.
Any ideas?
Sounds like you've got only a partial XML file. I'd try rerunning it, see
if it's an oddball error that doesn't reoccur. If so, look at the XML file
complete.
Kevin Simon
cooner_55421
report
Hi,
"Unexpected end of file has occurred. The following elements are not closed:
This error occurs from a copy of the Time Phase report I'm trying to make. I
Any ideas?
