This is definitely bpm related, even if they are not active the compiled
code is still lurking out there, and when the schema changes between
releases this is the error you get if you don't recompile the bpms. To
recompile find one on the sales order then make it active, save it the
make it inactive again. (or find an active on, make it inactive, save,
then make active again).
Of Brian Roberts
Sent: Friday, February 18, 2011 10:45 AM
Subject: [Vantage] Error when trying to delete an order
I am seeing an unusual error when trying to delete any sales order in
9.05.602a. Error message & details below. This occurs for all sales
orders, including immediately after creating a brand new one with header
only -- no details, no shipments against it, etc. We have no BPMs
active and we get the same error with our screen customization disabled.
A support has been placed to Epicor, but has not produced a solution.
I'm hoping somebody here will have seen the error and could point me in
the right direction.
Error popup after clicking delete: "Unexpected error - see appserver
logs."
And the results choosing Detail on that error message is attached.
The log has these 2 lines:
[11/02/18@09:31:20.695-0500] P-001596 T-005744 1 AS -- (Procedure:
'Update bo/SalesOrder/SalesOrder.p' Line:0) The caller's temp-table
parameter ttOrderHed does not match to the target temp-table ttOrderHed.
(5363)
'Update bo/SalesOrder/SalesOrder.p' Line:0) Parameters for procedure
Update bo/SalesOrder/SalesOrder.p (table ttOrderHed and table
ttOrderHed) do not match. (12311)
Any suggestions?
Brian Roberts
Business Systems Analyst
Ground Effects Ltd
Exception caught in: Epicor.Mfg.AD.SalesOrder
Error Detail
Message: Unexpected error - see appserver logs.
Type: Error
Program:
Method:
Table:
Row:
Field:
Stack Trace
at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.Delete(DataRow dr)
at Epicor.Mfg.UI.App.SalesOrderEntry.Transaction.Delete()
Inner Exception
ERROR condition: The Server application has returned an error. (7243)
(7211)
Inner Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID,
String procedureName, ParameterSet parms, Boolean persistent, Boolean
internal_Renamed, Int64 procId, MetaSchema localSchema, Int32
stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
requestID, String fullProcedureName, ParameterSet inparams, Object
procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
at
Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(Strin
g procedureName, ParameterSet parameters, MetaSchema metaSchema)
at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String
methodName, ParameterSet parameters, MetaSchema metaSchema,
BLConnectionPool connPool, Session connection, PersistentProc
persistProc, CallContextDataSet callContextDataSet)
at Epicor.Mfg.Proxy.SalesOrderImpl.Update(SalesOrderDataSet ds)
Of Brian Roberts
logs."
(5363)
Any suggestions?
Brian Roberts
Ground Effects Ltd
Error Detail
Type: Error
Program:
Method:
Table:
Row:
Field:
Stack Trace
Inner Exception
(7211)
Inner Stack Trace
stateModel)
at
