Has anyone ever run into an error like the one below with this report? Nothing has changed in our system since the report was last run 3 days ago.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: [A]System.Action2[System.Data.SqlClient.SqlDataReader,System.Collections.Generic.List
1[Erp.Internal.AR.GenAdvBillDep+OrderDtl2]] cannot be cast to [B]System.Action2[System.Data.SqlClient.SqlDataReader,System.Collections.Generic.List
1[Erp.Internal.AR.GenAdvBillDep+OrderDtl2]]. Type A originates from ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ in the context ‘LoadNeither’ at location ‘C:\Windows\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll’. Type B originates from ‘mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’ in the context ‘LoadNeither’ at location ‘C:\Windows\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll’.
Stack Trace:
at Epicor.ServiceModel.Tableset.DataReaderToTableDelegateCache.GetItem[TData](SqlDataReader reader, Type tableType, IceColumnCollection columns) in C:_Releases\ICE\3.1.500.8\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DataReaderToTableDelegateCache.cs:line 60
at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader, List1 table, IceColumnCollection iceColumns) in C:\_Releases\ICE\3.1.500.8\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 75 at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader, List
1 table) in C:_Releases\ICE\3.1.500.8\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 62
at Epicor.ServiceModel.Tableset.DBReaderAdapter.LoadFromReader[TData](SqlDataReader reader) in C:_Releases\ICE\3.1.500.8\Source\Shared\Framework\Epicor.ServiceModel\Tableset\DBReaderAdapter.cs:line 28
at Ice.Lib.ExecuteQuery.executeQuery[TRow](String sqlQuery) in C:_Releases\ICE\3.1.500.8\Source\Server\Internal\Lib\Ice.Lib.Shared\ExecuteQuery\ExecuteQuery.cs:line 209
at Ice.Lib.ExecuteQuery.Run[TRow](String[] pcTableName, String[] pcEFL, String[] pcFieldName, String[] pcJoinType, String[] pcWhereClause, String pcOrderBy, Int32 piRowIdBuffer, List1 hResultTable, String& pcErrorMsg, Boolean includeUDFields) in C:\_Releases\ICE\3.1.500.8\Source\Server\Internal\Lib\Ice.Lib.Shared\ExecuteQuery\ExecuteQuery.cs:line 152 at Erp.Internal.AR.GenAdvBillDep.BuildOrderDtlQuery(OrderDtl2List ttOrderDtlRows) in C:\_Releases\ERP\UD10.1.500.8\Source\Server\Internal\AR\GenAdvBillDep\GenAdvBillDep.cs:line 1144 at Erp.Internal.AR.GenAdvBillDep.BuildTempTable(List
1 ttAdvDepLineRows) in C:_Releases\ERP\UD10.1.500.8\Source\Server\Internal\AR\GenAdvBillDep\GenAdvBillDep.cs:line 1185
at Erp.Internal.AR.GenAdvBillDep.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ERP\UD10.1.500.8\Source\Server\Internal\AR\GenAdvBillDep\GenAdvBillDep.cs:line 776
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\3.1.500.8\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 93
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\3.1.500.8\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 54
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\3.1.500.8\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\3.1.500.8\Source\Server\Services\Lib\RunTask\RunTask.cs:line 526
at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in C:_Releases\ICE\3.1.500.8\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 87
at SyncInvokeRunTask(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.8\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func
2 func) in C:_Releases\ICE\3.1.500.8\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\3.1.500.8\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
