Excel or Access Gurus
Assuming that you have all of the 2007 parts on the 2008 Sheet, you can
do a lookup of the 2008 part on the 2007 sheet and if available, bring
in the appropriate column.
Generally I would do a
IF( ISNA( VLOOKUP(lookup_value, table_array, col_index_num,
[range_lookup]) ), " ", VLOOKUP(lookup_value, table_array,
col_index_num, [range_lookup]) ).
The Range Lookup should always be FALSE, this way you don't get the
nearest item. If it's not there you get an N/A so the NA test determines
whether to use the lookup or not.
Now all of the data is on one sheet.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2WTech.com
Of Jonathan Lang
Sent: Tuesday, March 10, 2009 11:02 AM
Subject: RE: [Vantage] Excel or Access Gurus
Very nice William. I'll have to try bot and see which one works the
best.
Thank you all very much for your inputs. Very Helpfull.
-Jonathan
--- On Tue, 3/10/09, William Hannah <william.hannah@...
Date: Tuesday, March 10, 2009, 9:17 AM
Jonathan,
Another simple way would be to use the SUMIF function. Put the 2008
Data on one sheet with the 2007 data on the other. Use the Part Number
column on the 2007 sheet as the evaluation array and the Part number
cell on the 2008 sheet as the criteria. Have the columns from the 2007
sheet that you want included as the Sum Arrays.
I am sending you a quick example off-list.
Regards,
Bill
William Hannah
Director of Finance
William Frick & Company
Direct: 847.918.7338
www.fricknet. com
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Jonathan Lang
Sent: Tuesday, March 10, 2009 8:57 AM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Excel or Access Gurus
Sorry, My mail sent itself before I fininshed. I need all of the
information for 2007 and 2008 on each part number. Any ideas?
--- On Tue, 3/10/09, Jonathan Lang <lsbestinc@yahoo. com
<mailto:lsbestinc% 40yahoo.com> > wrote:
From: Jonathan Lang <lsbestinc@yahoo. com <mailto:lsbestinc%
40yahoo.com>
Subject: [Vantage] Excel or Access Gurus
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Date: Tuesday, March 10, 2009, 8:55 AM
It's days like this one that I just want yell, "WHY ME!"
Okay, here it is.
I need to combine two seperate Excel sheets with similar data. Here is
what I have in an example.
2007) Part Num, Acct No, Yr 2007 Price, 2007 Extended Price
2008) Part Num, Acct No, Yr 2008 Price, 2008 Extended Price
I need to have all of the data on the same excel sheet, BUT the part
Numbers have to match up and the 2007 and 2008 data for the part
numbers.
For example using the headings above:
A1234 1000
William Frick & Co's SmartMarkT RFID Named to 2008 Top Ten Products List
Â
Okay, here it is.
Â
I need to combine two seperate Excel sheets with similar data. Here is what I have in an example.
Â
Â
Â
I need to have all of the data on the same excel sheet, BUT the part Numbers have to match up and the 2007 and 2008 data for the part numbers.
Â
Â
A1234 1000
Â
Â
Sorry, My mail sent itself before I fininshed. I need all of the information for 2007 and 2008 on each part number. Any ideas?
Â
Okay, here it is.
Â
Â
Â
Â
Â
Â
A1234 1000
Â
Â
Hi Jonathan,
Likely, you can have each sheet in your workbook separately (2007data,
2008data,CombinedData). Copy whichever worksheet you want as the base
(2007 or 2008) to the CombinedData worksheet...Then use a named range
and vlookup to get data for the other year...
I will send a mini sample direct to you offline.
FYI,
Karen S
Of Jonathan Lang
<mailto:lsbestinc%40yahoo.com> > wrote:
From: Jonathan Lang <lsbestinc@... <mailto:lsbestinc%40yahoo.com>
Okay, here it is.
numbers.
A1234 1000
What will the vlookup function return if there is not a match on one of the
rows?
Jeff
Jonathan Lang
Sent: Tuesday, March 10, 2009 9:57 AM
From: Jonathan Lang <lsbestinc@... <mailto:lsbestinc%40yahoo.com> >
Okay, here it is.
A1234 1000
Jonathan,
Regards,
Bill
William Hannah
Director of Finance
www.fricknet.com
Of Jonathan Lang
Okay, here it is.
numbers.
A1234 1000
> the rows?
The last parameter of the VLOOKUP function determines that behavior. It will
either return the closest record or NULL.
The VLOOKUP will work only if the every part number is in both sheets. If a
part exists in target but not your source then you'll miss it completely.
If the number of records isn't too great, you could dump both sheets into
one adding a field for the year then take that sheet and do a pivot table.
That will give you all of the data in a single view of the data.
Mark W.
THANK YOU!. Awesome.
Date: Tuesday, March 10, 2009, 9:04 AM
Hi Jonathan,
2008data,CombinedDa ta). Copy whichever worksheet you want as the base
(2007 or 2008) to the CombinedData worksheet... Then use a named range
FYI,
Karen S
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Jonathan Lang
From: Jonathan Lang <lsbestinc@yahoo. com <mailto:lsbestinc% 40yahoo.com>
Okay, here it is.
numbers.
A1234 1000
Very nice William. I'll have to try bot and see which one works the best.
Â
Â
-Jonathan
Jonathan,
Regards,
Bill
William Hannah
Director of Finance
www.fricknet. com
Of Jonathan Lang
Okay, here it is.
numbers.
A1234 1000
If it'll all fit on one sheet, do that & then create a pivot table (part number as y axis & year as x axis. Then dump your price and extended price into the table.
Rob
Date: Tuesday, March 10, 2009, 9:55 AM
Â
Okay, here it is.
Â
Â
Â
Â
Â
Â
A1234 1000
Â
Â
