Extra field on PartTranHist data view - 10.0.7
Could you create a POST Method Directive on Erp.PartTranHist on Method RunPartTranHistory with simply adding the EmpID as EntryPerson otherwise UserID?
I have also seen someone just hijack the PCID2 field which they have no intention to use PCID2 and just renaming the Grid Column.
var PartTranHistory =
		(from ph in ttPartTranHist
		join pt in Db.PartTran.With(LockHint.NoLock) on ph.TranNum equals pt.TranNum
		select new { HistoryRow = ph, EmployeeID = pt.EmpID }
		).ToList();
foreach (var row in PartTranHistory)
	 //row.HistoryRow.PCID2 = row.EmployeeID;
   if (row.EmployeeID != string.Empty)
        // Or even splitting it showing both on 1 column
   	row.HistoryRow.EntryPerson = string.Format("{0} / {1}", row.EmployeeID, row.HistoryRow.EntryPerson);
   else
     row.HistoryRow.EntryPerson = row.EmployeeID;
EDIT: Don’t join on the ttTable - this is an old Query. Just extract it out of there.
