Check out our standard details and other product information available on our web site at www.ncp-inc.com
CONFIDENTIALITY: This email communication may contain CONFIDENTIAL INFORMATION and is intended only for the use of the intended recipients identified above. If you are not the intended recipient of this communication, you are hereby notified that any unauthorized review, use, dissemination, distribution, downloading, or copying of this communication is strictly prohibited. If you have received this communication in error, please immediately notify us by reply e-mail, delete the communication and destroy all copies.
On Thu, Oct 2, 2014 at 9:04 AM, 'Bethany Rye' brye@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><div><p class="ygrps-yiv-2109438049MsoNormal">If you want to ship from inventory, make sure the “Make Direct†checkbox is unchecked. The “Buy to Order†checkbox is for parts you may sell that you buy already manufactured from a supplier and send them on to your customer (in other words, you are just the middle man).<u></u><u></u></p><p class="ygrps-yiv-2109438049MsoNormal"><u></u> <u></u></p><p class="ygrps-yiv-2109438049MsoNormal">You said that you do not keep inventory on parts. Is that only the parts you sell or does this include the raw materials you use to make parts?<u></u><u></u></p><p class="ygrps-yiv-2109438049MsoNormal"><u></u> <u></u></p><p class="ygrps-yiv-2109438049MsoNormal">If it is only the parts you sell, you will not want to have your parts as “Make Directâ€. Make Direct does not look at what raw materials you have in inventory to make the part. It gives you PO suggestions to buy material directly for the job, even though you may have the materials already in inventory to make the item.<u></u><u></u></p><p class="ygrps-yiv-2109438049MsoNormal"><u></u> <u></u></p><p class="ygrps-yiv-2109438049MsoNormal">Advanced Material Management will give you visibility of parts running through WIP. It is a lot of work to set it up though. If you go that route, you will want to set it up in a test environment and test it out thoroughly. Read up on it. There are quite a few benefits you get from it, but you have to be willing to put the work in to get the results you want.<u></u><u></u></p><p class="ygrps-yiv-2109438049MsoNormal"><u></u> <u></u></p><p class="ygrps-yiv-2109438049MsoNormal" style="margin-bottom:12.0pt;"><b><span style="font-size:10.0pt;color:#404040;">Bethany Rye</span></b><span style="font-size:12.0pt;"><br></span><span style="font-size:10.0pt;color:#404040;">Epicor Business Analyst – PTI Engineered Plastics</span><span style="font-size:12.0pt;"><br><br></span><u></u><u></u></p></div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
