File Attachment Share issues
I checked with another resource that has file attachment working and the svc account doesn't have access to the share just the users.
On Friday, May 20, 2016 12:51 PM, "Kimberley White faepigrl@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1864906787yiv7809073561ygrp-text">
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;">Ok I will test this but why does it work on my local PC.&nbsp; I don&#39;t have the service account set up on my local PC.<br clear="none"><div><span></span></div> <div class="ygrps-yiv-1864906787yiv7809073561qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-1864906787yiv7809073561yqt2270664347" id="ygrps-yiv-1864906787yiv7809073561yqt65894"><div style="display:block;" class="ygrps-yiv-1864906787yiv7809073561yahoo_quoted"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"><font face="Arial" size="2"> On Friday, May 20, 2016 11:15 AM, &quot;Techno Babbler TechnoBabbly@... [vantage]&quot; &lt;vantage@yahoogroups.com&gt; wrote:<br clear="none"></font></div>  <br clear="none"><br clear="none"> <div class="ygrps-yiv-1864906787yiv7809073561y_msg_container"><div id="ygrps-yiv-1864906787yiv7809073561"><div>
  <div></div><div dir="ltr">It&#39;s not using your file permissions, it is using the file permissions of the process that is running Epicor.<div><br clear="none"></div><div>Do you use a service account to run Admin Service for OpenEdge? if so, make sure that account has access to the share.</div><div><br clear="none"></div><div>Also, as a side note, I would suggest using MS DFS instead of a server name and share name, because it can be a massive mess down the line if you change servers and have to rename all the servers and shares instead of just moving the network location in MS DFS.</div><div><br clear="none"></div><div><br clear="none"></div></div><div class="ygrps-yiv-1864906787yiv7809073561yqt3894310810" id="ygrps-yiv-1864906787yiv7809073561yqt87224"><div class="ygrps-yiv-1864906787yiv7809073561gmail_extra"><br clear="none"><div class="ygrps-yiv-1864906787yiv7809073561gmail_quote">On Fri, May 20, 2016 at 11:06 AM, Kimberley White <a rel="nofollow" shape="rect" target="_blank" href="mailto:faepigrl@...">faepigrl@...</a> [vantage] <span dir="ltr">&lt;<a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt;</span> wrote:<br clear="none"><blockquote><span title="qreply"> <blockquote class="ygrps-yiv-1864906787yiv7809073561gmail_quote" style="border-left:1px #ccc solid;">
So I am setting up File Attachment in Epicor 9.  I created a network share and gave me full control to the share.  When I try to add an attachment I get the following error.  Current user does not have access to the File System pat \\xxxx\EpiAttach\TIMCO\Part.  I know the TIMCO and PART folder are created upon adding the attachment.  I am not sure why it is not working.  I had tested it by setting up a share on my local PC and it works fine.
Thanks Kim
</div>
<div class="ygrps-yiv-1864906787yiv7809073561yqt3894310810" id="ygrps-yiv-1864906787yiv7809073561yqt24008"><div style="color:#fff;height:0;"></div></div>
</div>
<div class="ygrps-yiv-1864906787yiv7809073561yqt2270664347" id="ygrps-yiv-1864906787yiv7809073561yqt80053"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561 -- #ygrps-yiv-1864906787yiv7809073561ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp #ygrps-yiv-1864906787yiv7809073561hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp #ygrps-yiv-1864906787yiv7809073561ads {
margin-bottom:10px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp .ygrps-yiv-1864906787yiv7809073561ad {
padding:0 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp .ygrps-yiv-1864906787yiv7809073561ad p {
margin:0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mkp .ygrps-yiv-1864906787yiv7809073561ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ygrp-lc #ygrps-yiv-1864906787yiv7809073561hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ygrp-lc .ygrps-yiv-1864906787yiv7809073561ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity span {
font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity span span {
color:#ff7900;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561activity span .ygrps-yiv-1864906787yiv7809073561underline {
text-decoration:underline;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561attach div a {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561attach label a {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561bold a {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 dd.ygrps-yiv-1864906787yiv7809073561last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 dd.ygrps-yiv-1864906787yiv7809073561last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 dd.ygrps-yiv-1864906787yiv7809073561last p span.ygrps-yiv-1864906787yiv7809073561yshortcuts {
margin-right:0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561attach-table div div a {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561attach-table {
width:400px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561file-title a, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561file-title a:active, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561file-title a:hover, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561file-title a:visited {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561photo-title a, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561photo-title a:active, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561photo-title a:hover, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div.ygrps-yiv-1864906787yiv7809073561photo-title a:visited {
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 div#ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg #ygrps-yiv-1864906787yiv7809073561ygrp-msg p a span.ygrps-yiv-1864906787yiv7809073561yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561green {
color:#628c2a;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 o {
font-size:0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561photos div {
float:left;width:72px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561reco-category {
font-size:77%;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561reco-desc {
font-size:77%;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 .ygrps-yiv-1864906787yiv7809073561replbq {
margin:4px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg select, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 input, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg pre, #ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 code {
font:115% monospace;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-mlmsg #ygrps-yiv-1864906787yiv7809073561logo {
padding-bottom:10px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-msg p#ygrps-yiv-1864906787yiv7809073561attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-reco #ygrps-yiv-1864906787yiv7809073561reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-sponsor #ygrps-yiv-1864906787yiv7809073561ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1864906787 #ygrps-yiv-1864906787yiv7809073561 #ygrps-yiv-1864906787yiv7809073561ygrp-vital ul li:last-child {
border-right:none !important;}
Thanks Kim
It's not using your file permissions, it is using the file permissions of the process that is running Epicor.
On Fri, May 20, 2016 at 11:06 AM, Kimberley White faepigrl@... [vantage] <vantage@yahoogroups.com> wrote:
Thanks Kim
Ok I will test this but why does it work on my local PC.  I don't have the service account set up on my local PC.
On Friday, May 20, 2016 11:15 AM, "Techno Babbler TechnoBabbly@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1494238349yiv0754435421ygrp-text">
  <div></div><div dir="ltr">It&#39;s not using your file permissions, it is using the file permissions of the process that is running Epicor.<div><br clear="none"></div><div>Do you use a service account to run Admin Service for OpenEdge? if so, make sure that account has access to the share.</div><div><br clear="none"></div><div>Also, as a side note, I would suggest using MS DFS instead of a server name and share name, because it can be a massive mess down the line if you change servers and have to rename all the servers and shares instead of just moving the network location in MS DFS.</div><div><br clear="none"></div><div><br clear="none"></div></div><div class="ygrps-yiv-1494238349yiv0754435421yqt3894310810" id="ygrps-yiv-1494238349yiv0754435421yqt87224"><div class="ygrps-yiv-1494238349yiv0754435421gmail_extra"><br clear="none"><div class="ygrps-yiv-1494238349yiv0754435421gmail_quote">On Fri, May 20, 2016 at 11:06 AM, Kimberley White <a rel="nofollow" shape="rect" target="_blank" href="mailto:faepigrl@...">faepigrl@...</a> [vantage] <span dir="ltr">&lt;<a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt;</span> wrote:<br clear="none"><blockquote><span title="qreply"> <blockquote class="ygrps-yiv-1494238349yiv0754435421gmail_quote" style="border-left:1px #ccc solid;">
Thanks Kim
</div>
<div class="ygrps-yiv-1494238349yiv0754435421yqt3894310810" id="ygrps-yiv-1494238349yiv0754435421yqt24008"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421 -- #ygrps-yiv-1494238349yiv0754435421ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp hr {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp #ygrps-yiv-1494238349yiv0754435421hd {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp #ygrps-yiv-1494238349yiv0754435421ads {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp .ygrps-yiv-1494238349yiv0754435421ad {
padding:0 0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp .ygrps-yiv-1494238349yiv0754435421ad p {
margin:0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mkp .ygrps-yiv-1494238349yiv0754435421ad a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ygrp-lc #ygrps-yiv-1494238349yiv0754435421hd {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ygrp-lc .ygrps-yiv-1494238349yiv0754435421ad {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421actions {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity span {
font-weight:700;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity span:first-child {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity span a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity span span {
color:#ff7900;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421activity span .ygrps-yiv-1494238349yiv0754435421underline {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421attach {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421attach div a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421attach img {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421attach label {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421attach label a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421bold {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421bold a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 dd.ygrps-yiv-1494238349yiv0754435421last p a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 dd.ygrps-yiv-1494238349yiv0754435421last p span {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 dd.ygrps-yiv-1494238349yiv0754435421last p span.ygrps-yiv-1494238349yiv0754435421yshortcuts {
margin-right:0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421attach-table div div a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421attach-table {
width:400px;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421file-title a, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421file-title a:active, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421file-title a:hover, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421file-title a:visited {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421photo-title a, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421photo-title a:active, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421photo-title a:hover, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div.ygrps-yiv-1494238349yiv0754435421photo-title a:visited {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 div#ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg #ygrps-yiv-1494238349yiv0754435421ygrp-msg p a span.ygrps-yiv-1494238349yiv0754435421yshortcuts {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421green {
color:#628c2a;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 o {
font-size:0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421photos div {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421photos div div {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421photos div label {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421reco-category {
font-size:77%;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421reco-desc {
font-size:77%;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 .ygrps-yiv-1494238349yiv0754435421replbq {
margin:4px;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-actbar div a:first-child {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg table {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg select, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 input, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 textarea {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg pre, #ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 code {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg * {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-mlmsg #ygrps-yiv-1494238349yiv0754435421logo {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-msg p a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-msg p#ygrps-yiv-1494238349yiv0754435421attach-count span {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-reco #ygrps-yiv-1494238349yiv0754435421reco-head {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-reco {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ov li a {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ov li {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-sponsor #ygrps-yiv-1494238349yiv0754435421ov ul {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-text {
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1494238349 #ygrps-yiv-1494238349yiv0754435421 #ygrps-yiv-1494238349yiv0754435421ygrp-vital ul li:last-child {
