If you use check boxes label them (Both/True/False) to help remind users the 3 states.
That is what I have done and the users are OK with this.
Patrick Winter
Sent: Tuesday, February 23, 2016 08:07
Subject: [Vantage] Re: filter bit fields with tracker in dashboard
Epicor Support explained to me that using checkboxes as Tracker View search prompts doesn't work well since checkboxes support three states vs just two. Their recommendation was to create a calculated field that showed string values of 'true' or 'false' based on the original logical value. Then create a search prompt field based on that calculated field. I will usually display the original logical field and not the calculated field in the grid so the checkboxes are displayed but then create the search prompt based on the calculated field.
Bob Beaghan
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended and/or named recipient or recipients, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient or recipients is unauthorized and may be illegal. Any views or opinions expressed in this email are those of the author and do not necessarily represent those of the Specialty Screw Corporation. Warning: Although precautions have been taken to make sure no viruses are present in this email, Specialty Screw Corporation cannot accept responsibility for any loss or damage that may arise from the use of this email or attachments.
