Form UI Script Won't Save
Okay–I’m losing my mind here.
I have a UI customization on a BPM data form that has been working great.
Requirements have changed, however, and I need to set one of the fields in the script to true instead of false. I do so, then save the customization. If I reopen the customization still in developer mode, the field I changed the value of flips back to false! Wtf?!
I tried clearing my cache and saving it as a brand new customization, but my changes won’t stick. What gives??
Okay–so I was able to get it to stick via the Customization Maintenance, but still–what gives with the developer mode not saving?
I know it’s been awhile, but did you ever figure out what the issue was? We’re running Epicor 10.1.500.16 and I’m having the same issue with the UI customization not saving.
Nope, sorry. For BPM Data Forms, I still use Customization Maintenance to this day.
We’re currently on 10.2.600.18.
Hii, please, can you help specify what you did on Customization Maintenance?
When I used the BPM Data Form Designer to create a form, and then use the developer mode to customize it, the customization never saves…
Do you know anything about this?
Thanks for all the help!
