Forward Finite Scheduling
Thank you, for awhile I was beginning to think we are the only ones, which would lead to a configuration or data problem. We have been working with Phil at tech support. We have this issue in the line up for develpment to review.
Â
Sent: Mon, November 16, 2009 9:39:11 PM
Subject: Re: [Vantage] Forward Finite Scheduling
Â
We are having the exact problem. I think they have submitted a SCR to development for this. Been working with Warren and Scott at tech support.
By the way we are on 408B as well.
Sent from my Verizon Wireless BlackBerry
Date: Mon, 16 Nov 2009 17:19:40
To: <vantage@yahoogroups .com>
Subject: [Vantage] Forward Finite Scheduling
Ver, 8.03.408B
Is anyone using forward finite scheduling for one job at a time, and not running global scheduling?
Are you having any problems?
We are experiencing the job will skip over available capacity and schedule at a later date.
Ver, 8.03.408B
To: <vantage@yahoogroups.com>
Ver, 8.03.408B
I recall during piloting a few years ago on one of the 305's, we observed this behavior (even for jobs scheduled into our infinite capacity, high velocity, assemble to order resources). Jumping to 403 resolved it.
We run Global scheduling (finite in our machine shop resources with all jobs being forward scheduled & carrying various scheduling priority multipliers via preset scheduling codes) on 405a - & while it has major bugs unresolved a year+ after reporting them (to Warren) & being a promised a fix (that never materialized) on 408 - I've never seen the behavior you describe on 403-405a.
Tying into the 'reasons to upgrade' thread (sorry Kerry: I typed 'Dawn' when seconding your wise stance to only upgrade when compelling reasons exist) - This is an example of why we don't blindly upgrade unless there is a truly compelling reason. (Each release seems to bring new bugs to deal with - often as many as it supposedly resolves - and often the 'fixes' are for things not impacting our process use of the system - but the new bugs ARE when we do initial testing assessment of whether to adopt the new release).
RobÂ
Sent: Mon, November 16, 2009 8:19:40 PM
Â
Ver, 8.03.408B
Rob, what ver are you on now? What global scheduling bugs have you identified? The other issue we saw was when rescheduling a job with a subcontract operation which has a PO linked to it, the days out is ignored, there is a fix which isn't coming out until 410 release.
Lou
Sent: Tue, November 17, 2009 1:01:19 PM
Subject: Re: [Vantage] Forward Finite Scheduling (& tie in to Reasons to Upgrade thread)
Â
RobÂ
____________ _________ _________ __
To: vantage@yahoogroups .com
Â
Ver, 8.03.408B
Lou,
We're on 405a & run MRP & Global nightly as recurring tasks.
404 (where global was split into 3 app process of Calc Global Sched order, adjust (which we don't do as our shed codes - each w/ a specific priority multiplier & adjusted by planners thru-out day - give a good sched order) Sched Order & Global) revealed immediately long standing bug of Calc Sched order using as-sched due date (versus entered fixed job Req'd date) - meaning you could run 3 step process repeatedly (during a time when no activity is reported, jobs changed by planners, new jobs entered or WIP jobs rcv'd) - would give you 3 different schedules as use of wrong date made it based on prior sched versus planned/wanted sched.
We reported to Vantage fully documented (along with our own SQL fix of temp swapping Due w/ Req'd) & Epicor leveraged our fix into fixed code by 404c.
Still existing is a random, widespread (impacting 30-40 pct jobs on any given night) is no respect for finish to start relationship of our OPs.
It can sneekily result (for ex) in OP 50 scheduled to start before OP 20. (It'll break defined seq at any OP - but only 1 per affected job & subsequent OPs return to respecting spec'd sequence.) Blatant ones have last OP (out of up to 20 but typically about 8 per job) starting before 1st - with job then showing DUE before job Start.
Reported it a year ago & Warren at support promised resolution in 408 (which was released months later than original est).
Took a single test install & global run to find bug still exists.
I suppose we'll test 409 nxt month when released but not holding our breath.
We also experience your issue with subcontract offset days (when linked PO exists). Many systems I've used or seen struggle with this one. It's annoying (but relative to larger problem with Op sequencing being broken) I can live with it as most of our subcontract services are out 2-5 days max.
Rob
--- Original Message ---
Sent:Tue 11/17/09 8:24 pm
To:vantage@yahoogroups.com
Subj:Re: [Vantage] Forward Finite Scheduling (& tie in to Reasons to Upgrade thread)
Lou
Â
RobÂ
Â
Ver, 8.03.408B
That's interesting that you are experiencing those finish to start
issues Rob. We aren't seeing any of that here. The scheduling engine
is far from being robust as is should, I still do have issues with how
calculate runs, but with our aggressive use of priority codes it has
become...workable. Another user posted on here earlier about operations
skipping open capacity, and we do see that crop up from time to time on
a smaller percentage of jobs, more so on zero level jobs than not, but
this has to this point for us been more of an annoyance than anything,
we usually mop these up by a crystal report we use to monitor
manufacturing critical path time to ensure our velocity is where we want
it.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of robertb_versa@...
Sent: Wednesday, November 18, 2009 12:17 AM
Upgrade thread)
Lou,
by 404c.
breath.
2-5 days max.
Rob
From:"Lou Laird" <loulrd@... <mailto:loulrd%40yahoo.com> >
To:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Upgrade thread)
Lou
<mailto:robertb_versa%40yahoo.com> >
Upgrade thread)
resolved it.
Rob
Ver, 8.03.408B
