Log In - Epicor Identity - a few related Ideas out there on this, hereās mine.
Thereās a thread here also:
Hey⦠dont be so negative⦠we literally have discussed this idea the past two releases for scoping⦠but the discussions have followed much the same path as has been discussed here. We donāt want to add confusion, but we DO want clarity in what the Pull as assembly, plan as assembly, Purchase Direct, Make Direct, Non-Stock, Non-Quantity bearing, and phantoms all mean, and how they interrelate. if we just go and change this, it could make what already works and what everyone understands become confusing.
So.. while we again discussed this for 2025.2, it is still not āin developmentā because we dont have a great answer, and dont want to cause confusion. Someday, we will either mark this idea as āin developmentā, or as an idea that we will not be doing.
I did some brief testing with this field a few years ago at a previous company (so 2022.x.x, I think) and found it to not behave like you think it would and/or not consistently. I donāt recall exactly what I found with it that I didnāt like, but it seemed like one of those āuse at your own riskā type of settings.
I also remember it being wonky.
Already exists in the Technical Reference Guides.
Yes and no. You cannot use nonstock with source type transfer and I was not able to find this clearly explained anywhere.
I pop in and download any new documentation as it appears, organized by major and minor version. At a glance, version 2024 is associated with 117 distinct reference guides, 53 of which have been modified for 2024.2.
Control-F usually works out if youāre in the right document. Sometimes itās more efficient to install WSL, sudo apt install pdfgrep, figure out how that works, then grep all the docs that youāve copied to your own storage.
Add Lot # to Material Request Applications ā this is to add a Lot field to all the material request/ inventory request applications as an optional field to support shade lot matching/ tracking efforts and have the selected lot # appear on the material request queue.
Undo Operation/ Job Batches ā we utilize job batching pretty heavily, and when a mistake is made, the only recourse is to close all the affected jobs and re-run MRP for new unfirm suggestions ā not fun, and time consuming. We should have the ability to undo batches and return the jobs back to their original state assuming no transactions have been made against them.
Hereās a good one:
Allow help to be accessed externally
With increasing mass of documentation migrating to Zendesk online help, technical references are losing relevancy and are falling out of date.
Searching from the Kinetic client or within the Zendesk portal doesnāt produce results specific enough to reliably be relevant. The online help search does not recognize search term arguments. Targeting a search to site:erphelp113100.zendesk.com in a search engine that respects search term arguments would be extremely useful.
For example, the quotes around āauto consume stockā are a search term that mean I want to match that phrase, not every possible etymological construct, synonym, or Levenshtein distance <= 5 of āautoā and/or āconsumeā and/or āstockā.
Just added this. It existed in Classic but not in Kinetic.
Add Fiscal Year and Period functions to Kinetic BAQ designer
You can still do this in Kinetic, but there is no place to select it.
New idea for you to consider:
Apply SNAP Programming interface to BPM logic - KIN-I-6081
haha sorry Tim imā
on this one. BPMS are FINE!!! donāt touch it!!!
Programming via mouse click and widget is THE WORST
Visual Programming is slow and inefficient. Leave BPMs alone, if you add this in please have an option that says I know what I am doing and it makes all this go away and lets you go back to writing BPMs the way we do them today.
Unpopular Opinion Perhaps: Visual Programming doesnāt make programming more accessible to less technical people, it makes technical people more frustrated and puts a powerful (read dangerous) tool in the hands of individuals that are generally not qualified to do so. There should be a non trivial learning curve to modifying core Method Logic
If you click on his idea, its only about replacing the current BPM diagrams with these, not code, as far as I can tell.
Still, its a waste of dev time when we have so many worse issues to deal with.
In replacement for normal widget building iām down with it, but for c# replacement please no.
Make this an option for users, but still keep the c# code, but there are way more core UI bugs and heavily voted on features that need to be addressed first.
I might be overthinking it, but it seems like with App Studio they replaced a complex product with a steep learning curve with a crippled, āmore accessibleā version to help the masses.
The masses still canāt use it, and now those of us with technical know-how have to jump through endless hoops for trivial tasks.
If they want to improve the BPM Editor embeding VS Code with auto complete and copilot would be much better received
I see loops on the legend, so if it brings loops to the current widget world, Iām for it.
1000% Agree. I always have to go back and remind myself.
In conjuncton with notebooklm ![]()
Or⦠(Now hear me out)⦠Just add a āloopā function/widget to the current toolset. That should be easier than shoe-horning in a whole new system.
Please stop āfixing thingsā that arenāt brokenā¦
