Generating blank tags only for full physical inventory
WE just completed our first Phyisical inventory with 9.05.702 and you can not generate your own tag numbers at this time. you genereate the tags after initializing the invnetory and then you can select how many blank tags to print or after you have printed the tags you can go and generate tags and it will ask how many blnaks and will only generate the blank tags. when you print make sure that you check the box for print blank tags.
--- In vantage@yahoogroups.com, "carol.pelowski" <cmpelows@...> wrote:
> Hi all,
> Currently in Vantage 8.03.409C we can generate blank tags when we do our inventory which upon tag entry we can enter our own tag numbers and this works well for our company. In testing E9.05.701 we have not found a way to create our own tags. The option to select blank tags only is grayed out. Does anyone on 701 create their own tags and if so , have you found a work-around for this?
> Please and thanks for any help.
> Carol
Hi all,
Carol
