Getting "Open With" from a custom ultra combo
What version?
Have you tried a quick search?
Ann Fisher
Advantage Business Creations
Advantage@wcoil com
www.advantagebusinesscreations.com
Sent from my Verizon Wireless BlackBerry
Date: Mon, 20 Jul 2009 19:40:36
To: <vantage@yahoogroups.com>
Subject: [Vantage] Re: Getting "Open With" from a custom ultra combo
In Epicor9 you can get it to work with a textbox but not an ultracombo
..02
--- In vantage@yahoogroups.com, Thomas Rose <t.rose@...> wrote:
> I'm referencing Key1 in UD07 from Part entry. So, if I understand you correctly, the system is going to decide for me whether or not that table/field cross reference combination is going to have an Open With option or not? Further, I could experiment with different UD tables and different fields within a UD table, and eventually I may (or may not) stumble across a combination that works?
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> "The World Leader in Back-lit Mirrors & Mirror TV Technology"
> T 425 776-4946
> A 11831 Beverly Park Rd, Bldg D, Everett, WA 98204 USA
> www.electricmirror.com<http://www.electricmirror.com>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
> Sent: Monday, July 20, 2009 10:06 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Getting "Open With" from a custom ultra combo
> I believe context menu has more to do with what field in a particular
> table than what type of control you are using. I have tried a number of
> different context menu's and have had less success when I try using a
> field that isn't a key field in a table (i.e. partnum, jobnum etc..).
> Though I have not tried Key1 in a UD table to date. I am fairly
> confident that the control being a combo box should have little to do
> with it, it will be more to whether or not Vantage will allow you to use
> a UD table. It would not for example work if you tried the ShortChar01
> off the JobOper table, but it would the JobNum from the JobOper...
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> Of Thomas Rose
> Sent: Monday, July 20, 2009 11:04 AM
> Subject: [Vantage] Getting "Open With" from a custom ultra combo
> I have added an ultra combo box to my form which references a UD table.
> On standard combo boxes already on the form, you can right click to get
> "Open With...". I would like that behavior on my custom ultra combo. Can
> that be done? Easily?
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
I have added an ultra combo box to my form which references a UD table. On standard combo boxes already on the form, you can right click to get "Open With...". I would like that behavior on my custom ultra combo. Can that be done? Easily?
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Rob Bucek
FAX: (715)284-4084
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Rob Bucek
FAX: (715)284-4084
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Ill hazard a bet that If it isn't a key field you probably won't get it
to work. Your combo box won't be your constraint. Try the Key1 off
your UD table, im curious to see if it would work. I just haven't tried
a Key1 UD opens with before. Which UD table it is wont matter. Youll
see similar behavior elsewhere in Vantage like this (eligible BAM
tables, Auto printing, Advanced Searches), they are somewhat restricted.
Rob Bucek
FAX: (715)284-4084
Of Thomas Rose
Sent: Monday, July 20, 2009 12:19 PM
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
I am trying to reference Key1 in UD07, but that is not working. Oh well.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Sent: Monday, July 20, 2009 10:34 AM
Rob Bucek
FAX: (715)284-4084
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Rob Bucek
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Rob Bucek
FAX: (715)284-4084
On Behalf
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
There is a work around I came up with for this. If you can demonstrate
some relationship to a key field along your process you can tag from
that field. I was attempting that ShortChar01 on the JobOper table but
in the end still achieved what I was after by just using the JobNum
field instead and structuring my BAQ accordingly. Perhaps thinking
along these lines (if applicable in your case) might help.
Rob Bucek
FAX: (715)284-4084
Of Thomas Rose
Sent: Monday, July 20, 2009 12:34 PM
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
On Behalf
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
On
Behalf Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
On Behalf
Of Thomas Rose
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
.02
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
> Rob Bucek
> FAX: (715)284-4084
> Of Thomas Rose
> Thom Rose
> Controller
> Electric Mirror LLC
> HOTEL LUXURY
> T 425 776-4946
Oops - Let me retract that...
Ultra combos will show the context 'open with' if the EpiBinding and EpiContextMenuKey properties are filled in and match a context menu entry - I did not test if it passes the value from the control...
> .02
> > Thom Rose
> > Controller
> > Electric Mirror LLC
> > HOTEL LUXURY
> > T 425 776-4946
> > Rob Bucek
> > FAX: (715)284-4084
> > Of Thomas Rose
> > Thom Rose
> > Controller
> > Electric Mirror LLC
> > HOTEL LUXURY
> > T 425 776-4946
