I have a dashboard that returns records for UD103 Table.
Want to right click on the Key1 field in the dashboard and open with UD103Entry for the record they are on in either the grid or dashboard view.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> If you could outline exactly what you are trying to accomplish a bit
> more perhaps I can give you more detailed information.
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of mmcwilliams22
> Sent: Tuesday, August 31, 2010 12:48 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Dashboard Context for UD Tables "Open With"
> Changed the UD103.Key1 one to be like UD103.Key1 instead of blank.
> That did not seem to do the trick.
> I am guessing it will not work just like in a standard UD Form
> where you cannot link 2 ud tables using the custom colum like.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
> Bucek" <rbucek@> wrote:
> > Go back into customization, data tools, and you have to apply a 'like'
> > field to the Key1 field and apply it. So if you are storing a part
> > number in that field the like field property would be Part.PartNum.
> > Rob Bucek
> > FAX: (715)284-4084
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of mmcwilliams22
> > Sent: Tuesday, August 31, 2010 8:36 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Dashboard Context for UD Tables "Open With"
> > Creating a dashboard for a UD table. I cannot get it to display the
> > context "Open With" for key1 on any UD tables. Do I need to modify the
> > xml file in the client folder?
